First post, by Almoststew1990
I've had this card for a long time and I am looking to sell it as I never use it. I want to test it to make sure it is working. I recall it has power requirements (-5v rail) and maybe motherboard requirements (????) in order to work properly. I was going to test it on my 486 board which I've definitely paird with the card but I can't get it to boot.
I have a mid/late Slot 1 board with an ISA slot and an ATX power supply that definitely does -5v. Will the card work in this board? I don't want to damage either!
Reply 1 of 3, by Cyberdyne
It does not do somehing bad. But one problem is OPL2 is speed sensitive. 486+ are better with OPL3 based cards.
Reply 2 of 3, by Grzyb
It should work, but it also depends of software.
The FM synth (OPL2) is known for heavy distortions on fast CPUs if the software doesn't add proper delays.
Slot 1 CPUs are definitely fast enough for this problem to occur.
Nie tylko, jak widzicie, w tym trudność, że nie zdołacie wejść na moją górę, lecz i w tym, że ja do was cały zejść nie mogę, gdyż schodząc, gubię po drodze to, co miałem donieść.
