Dosbox 0.70 & Shadow Warrior
Having problems with a specific game or application? Post your problems here!
Postby raskil » 2007-3-09 @ 20:06
DosBox 0.70 refuses to run Shadow Warrior. It used to work wich 0.65, now i get a black screen after the graphics init. I' ve tried switching to normal core and static cycles and I' ve turned off sound, but i still get the black screen. Any ideas?
Greets
Raskil
Edit: Tried the DOS32a Extender too, but no luck.
raskil
Re: Dosbox 0.70 & Shadow Warrior
Postby red_avatar » 2007-3-09 @ 20:54
It works fine with the standard settings to be honest. Try a clean install of Blood? Also select VGA in setup.
User avatar
red_avatar
Postby Hazekel » 2007-3-09 @ 21:49
Assuming you are using Windows XP or later, I would recommend using the free port on this site:
http://jonof.edgenetwork.org/?p=jfsw
The game will run natively through Windows with this port. It runs better than with DOSBOX 0.65. Haven't tried 0.70 on this one.
User avatar
Hazekel
Postby raskil » 2007-3-09 @ 22:19
Got it working. A reinstall did the trick. Shadow Warrior runs quite good on 0.70, even in 800x600 SVG.
How good is the Multiplayer Code from the port?
raskil
Postby leileilol » 2007-3-10 @ 22:39
jfSW has fatal crashes in areas (especially mirrors) and has broken multiplayer though. For stability I still recommend DOSBox with SW.
Voodoo2s aren't 100mhz stock
Geforce256 isn't released as a beta on New Years '99 under the Quadro brand
386DX vs SX isn't about a missing FPU
DOS gaming isn't a bilinear 320x200 16:10
DOS PCs aren't better than the Macintosh
Old PCs aren't 'aesthetic'
User avatar
leileilol
Postby Wintermute » 2007-3-10 @ 23:17
I don't know about Multiplayer but I didn't experience any crashes with Jono's port on my computer.
Wintermute
Postby raskil » 2007-3-13 @ 21:36
What a beauty, SW runs great under DoxBox 0.70 even in 800x600 SVGA. And after a little trouble with the IPX frame type i got the multiplayer working too. LO WANG RALLY, I'M COMING! Many thx to all contributers of DosBox, you just made one person alot happier :)
raskil
Postby Wkdsht » 2007-6-12 @ 17:11
Havin trouble gettin Shadow Warrior running it says CFG not found what am i doing wrong... i'm wiggin out cause i been wantin to play this game again for years lol....
User avatar
Wkdsht
Postby MiniMax » 2007-6-12 @ 22:38
What did you do Wkdsht?
DOSBox 0.73 ReadMe | DOSBox Wiki | DOSBox 60 seconds guide | How to ask questions
_________________
Lenovo M58p | Core 2 Quad Q8400 @ 2.66 GHz | Radeon R7 240 | LG HL-DT-ST DVDRAM GH40N | Win 10 Pro
User avatar
MiniMax
Moderator
Location: Stockholm, Sweden, Europe, Earth Interests: Old games & young women
Postby leileilol » 2007-6-13 @ 19:05
then run setup.exe to make a new one
User avatar
leileilol
Postby Wkdsht » 2007-6-15 @ 16:36
I have re-installed it and went thru the set up and now i can do it but get no sound.
User avatar
Wkdsht
Postby wd » 2007-6-15 @ 16:37
What sound card and what settings did you choose in setup?
wd
DOSBox Author
Postby MiniMax » 2007-6-15 @ 17:33
MiniMax wrote:What did you do Wkdsht?
Let me try once more: EXACTLY what did you do Wkdsht?
_________________
User avatar
MiniMax
Moderator
Postby Wkdsht » 2007-6-15 @ 18:32
I installed the game went thru the setup like normal, then i go into DOSbox and get it goin and it says something about playback failed or something. Sorry for seeming so dense triin to learn some of this stuff still...
User avatar
Wkdsht
Postby MiniMax » 2007-6-15 @ 18:48
Trying one more time. EXACTLY, line by line, command by command, keypress by keypress.
_________________
User avatar
MiniMax
Moderator
Postby Wkdsht » 2007-6-15 @ 22:07
First i installed it ran the set up and everything then opend the dosbox changed the drive to C: then typed in SW like it says to then i will load up but while loading up it says playback failed possibly due to an invalid or conflicting IRQ.
User avatar
Wkdsht
Postby MiniMax » 2007-6-15 @ 22:17
I asked 3 times, and never got an answer, so I am not going to waste more time on you.
_________________
User avatar
MiniMax
Moderator
Postby Hillsy_ » 2007-6-19 @ 17:26
The game works fine with Dosbox 0.70 even with SVGA 800x600 as mentioned above. It seems you have the incorrect settings for your sound card. Try changing the IRQ and DMA channels when you choose your sound card when running the setup file.
Manually choose your sound card. Don't accept the default settings. It has an option 'Choose Sound Card'. Select it to choose your sound card. I find the best one is sound blaster or 100% compatable...
What sound card are you using?
Tinker alittle and you will find the right setting to run the game.
Old DOS game were very sound card sensitive. You have to get the correct settings. You will know when you have as when you test the sound and music in the setup file you will hear something...such as 'you don't mess with Lo Wang'...or something equally as amusing.
Enjoy.
Hillsy_
Postby Wkdsht » 2007-6-20 @ 15:56
Is it best to run the set up in DOSbox or just use set up during the install?
User avatar
Wkdsht
Postby wd » 2007-6-20 @ 15:58
Shouldn't matter, as long as you select the correct card with correct
parameters, that is irq=7 and dma=1
wd
DOSBox Author
Next
Return to DOSBox Games/Apps
Who is online
