Warcraft II
Emulation of old Macintoshes, Mac hardware, or Mac peripherals.
Warcraft II
Postby whistler » 2017-4-21 @ 00:35
I was able to mount the CD and the new directory that i was going to install it to with no issue. When i view the files on the CD without dosbox I can see the file names correctly. They look like this:
Custom PUDs
Data
Destop Folder
etc etc etc...
When I look at the files on the CD from dosbox the names are totally wrong. They look like this:
CUSTOM~1
DATA
DESKTO~3
I can not change directory no matter what i do and cant run the install files. What's wrong here?
whistler
Re: Warcraft II
Postby vladstamate » 2017-4-21 @ 01:04
Is this Warcraft II for Mac? If yes then DosBox cannot help you.
Plus DosBox is basically DOS and in DOS (unlike Windows 95+ or MacOS) file names are 8.3 so the names will be truncated.
User avatar
vladstamate
Re: Warcraft II
Postby collector » 2017-4-21 @ 12:57
If you are trying to use DOSBox ask in the DOSBox forum.
User avatar
collector
Re: Warcraft II
Postby Azarien » 2017-5-21 @ 15:30
DOSBox does not support LFN (long filenames).
There's unofficial patch somewhere on this forum, but I don't think that would solve your problem.
A DOS version of the game certainly would not require support for LFN to install.
Azarien
Re: Warcraft II
Postby collector » 2017-5-21 @ 22:33
Also note that this forum is for the emulation *of* Macs, not emulation *on* Macs.
User avatar
collector
Return to Macintosh Emulation
Who is online
