DOSBOX AND CLAMSHELL
Emulation of old Macintoshes, Mac hardware, or Mac peripherals.
Postby Ocean268 » 2011-1-16 @ 02:43
Ok what am I doing wrong
I have a Clamshell OS 10.3.
I downloaded DOSBOX .74
I clicked on the DOSBOX and it just blink once on the dashboard and disappears.
It does not open to a .prompt or a terminal.
Any suggestions
Ocean268
Re: DOSBOX AND CLAMSHELL
Postby Dominus » 2011-1-16 @ 16:39
it's not compiled for 10.3. You could try compiling it yourself from source and see whether it will work. But since many dependencies of Dosbox aren't supporting 10.3 either, that sounds like a huge work (finding the last version that works on 10.3, compiling that, compiling dosbox with that and then testing whether Dosbox works or not).
User avatar
Dominus
DOSBox Moderator
Postby Ocean268 » 2011-1-16 @ 17:18
Dominus wrote:it's not compiled for 10.3. You could try compiling it yourself from source and see whether it will work. But since many dependencies of Dosbox aren't supporting 10.3 either, that sounds like a huge work (finding the last version that works on 10.3, compiling that, compiling dosbox with that and then testing whether Dosbox works or not).
I have another Clamshell, Graphite, with Tiger 10.4 install. Will that work?
Ocean268
Postby Dominus » 2011-1-16 @ 17:20
it should
User avatar
Dominus
DOSBox Moderator
Postby Ocean268 » 2011-1-16 @ 21:20
Dominus wrote:it should
IT WORKS!!!!!!!!!!!
Thank you!!!!
Ocean268
Postby Ocean268 » 2011-1-16 @ 22:28
IT WORKS!!!!!!!!!!!
Thank you!!!!
I found .073 and this works on the clamshell 10.3!
Thanks again!
Ocean268
Postby Dominus » 2011-1-16 @ 22:30
Glad to be of service :)
(and I hope you don't intend to play too demanding games on either clamshell - Dosbox is a demanding program and demanding games need more power than thos clamshells can give, I think)
Oh, and if possible avoid the 0.73 version, mostly just because 0.74 is newer and includes many fixes.
User avatar
Dominus
DOSBox Moderator
Return to Macintosh Emulation
Who is online
