The last update to Basilik II was a patch created by the author, Lauri Pesonen, on March 29th 2002. It was a "gamma ramp patch" aimed at fixing the problem running Escape Velocity Nova under Basilisk II. This was in response to many emails asking him to get EVN to work under B2. The release was the BasiliskII.exe only - note that it was not JIT optimized.
Also notable is Christian Bauer pointed out that the latest (Linux) builds already include the required code ...
Christian:"Methinks you should update to the latest CVS sources."
Lauri: "You're so right of course -- and I will sooner or later..."
Before that, the last update was January 20, 2001 - build 142.
The last version of Basilisk II (general) was Release 0.9-1, May 31 2001.
And I know all this because I've been a follower of Emaculation for years! (http://www.emaculation.com)
(Although it seems to have only archived my posts as far back as April 2001 - their site archive's a bit funky due to hosting changes and lawsuits...)
http://www.google.com/search?q=site%3Awww.ema … tiletto&num=100
Information on Basilisk II here: http://www.emaculation.com/basilisk.shtml
Homepage of the Win32 Basilisk II port here:
http://www.nic.fi/~lpesonen/BasiliskII/
Homepage of Basilisk II here:
http://www.uni-mainz.de/~bauec002/B2Main.html
I think what's going on is that both lead developers are quite busy with work. Still, it's all open-source so people can continue working on it. I'd particularly like to see Basilisk II Win32 brought up to date with the main version, with Gwenole's JIT emulation and Lauri's own fixes, but I may be dreaming.
Good forums for Macintosh emulation questions are:
Here: http://forums.delphiforums.com/basilisk2/start
Here: http://forums.delphiforums.com/MacEmulation/start
Here: http://forums.delphiforums.com/macwindos/start
Here: http://www.emaculation.com/phpBB/index.php
do the Fandango!" - Queen
Stiletto
