Mac emulator and speed control
Emulation of old Macintoshes, Mac hardware, or Mac peripherals.
Postby swaaye » 2011-12-18 @ 01:48
I want to play Super Wing Commander. It runs too fast on SheepShaver. Is there a better emulator for speed control or is there a speed reduction app that doesn't cause insta-crashes with SheepShaver?
swaaye
Moderator
Re: Mac emulator and speed control
Postby robertmo » 2011-12-18 @ 07:00
SheepShaver is a PowerPC Emulator.
Super Wing Commander was designed for Motorola 68040.
Basilisk II is a Motorola 68040 emulator.
You made a wrong emulator choice for this game.
User avatar
robertmo
Postby swaaye » 2011-12-18 @ 15:26
It has 68k and PPC executables.
Besides I wasn't asking about HOW to run it. It plays TOO FAST. That is the issue here.
swaaye
Moderator
Postby robertmo » 2011-12-18 @ 15:36
it won't be too fast in basilisk for sure.
User avatar
robertmo
Postby swaaye » 2011-12-18 @ 16:05
OK I will try Basilisk and see what happens.
swaaye
Moderator
Postby MrKsoft » 2011-12-18 @ 17:56
Actually it will likely be even faster in Basilisk. The emulation overhead of a PPC vs a 68k is a lot higher, so emulating a PPC Mac is not as fast.
Those emulators unfortunately don't have any sort of speed control. You might want to look into MESS's Mac emulation, which is still in its infancy but actually sticks to the proper CPU speed. It might work, it might not.
Wafflenet OPL Archive - Preserving MS-DOS music in a unified format!
User avatar
MrKsoft
Postby Sune Salminen » 2011-12-19 @ 05:16
The Mac Quadra 700 MESS driver has "preliminary" status. I can't get it to boot with any of the System 7 HD images I have.
User avatar
Sune Salminen
Postby filipetolhuizen » 2011-12-19 @ 13:17
If Wing Commander runs in any 68k CPU, try choosing the 68020 or the 68030 for emulation in Basilisk II. This will certainly slow the game down if still too fast with the 68040.
User avatar
filipetolhuizen
Postby EkriirkE » 2015-10-05 @ 04:45
filipetolhuizen wrote:If Wing Commander runs in any 68k CPU, try choosing the 68020 or the 68030 for emulation in Basilisk II. This will certainly slow the game down if still too fast with the 68040.
CPU arch does not determine CPU speed
User avatar
EkriirkE
Postby filipetolhuizen » 2015-10-24 @ 14:10
Yes, but a 68020 or a 68030 are slower than a 68040 for sure.
User avatar
filipetolhuizen
Postby awgamer » 2015-10-24 @ 14:25
You can try mini vmac as well, which has speed selection.
awgamer
Postby swaaye » 2015-12-29 @ 06:18
Well in the meantime (since 2011) I was gifted a PowerMac 7500 so it's not a problem anymore. :)
swaaye
Moderator
Return to Macintosh Emulation
Who is online
Users browsing this forum: No registered users and 2 guests
