by Zup » 2017-12-21 @ 12:50
If you want to run OS X you should use PearPC, but it's not very good (it doesn't support some hardware). It was a promising emulator, but it was nearly abandoned when OS X was ported to Intel and it was possible to run it on a normal PC.
If you want to run OS 9 with a G3 processor, Sheepsaver can do the trick.
I'm selling some stuff!
