First post, by dr.zeissler
Hi there,
does someone have such a PC-Card in his Macintosh?
What PC-Card do you have and in what Mac is it installed?
What PC-Software/OS do you have installed?
Thx
Doc
Retro-Gamer 😀PowerMac 6100-66/Houdini 486/66 - G4 Cube 450/Rage128pro OS9.0.1 - Macintosh LC/Apple IIe Card OS6.0.8 - Acorn A4000 Archimedes - Unisys CWD 486/66 + Aztech Washington
Reply 1 of 6, by ifrit05
Always wanted a DOS/PC card for Macintosh, most I can find are for the PDS's, any of which I do not own.
SS7: GA-5AA 1.1 | K62+ 550 @ 600 | 512MB PC133 | V3 3000
A500: Stock
A1200: Indivision AGA MK2cr | ACA 1221
Apple IIGS
Macintosh IIci
Atari 800XL
Reply 2 of 6, by dr.zeissler
I do some and I do use them, but I am interested what other people have and what they do with them.
https://www.flickr.com/photos/94839221@N05/al … 157665671196304
Reply 3 of 6, by tokyoracer
I got a "DOS Compatible" Performa 630.
Really fun, very useable with it's 486 @66 and SoundBlaster Vibra module.
Running DOS 6.22 and Win 3.11.
Mac is running System 8.1 (would prefer 7.5.5 but it didn't like the DOS card on that OS).
Reply 4 of 6, by dr.zeissler
I also had this one, but the power supply died.
Reply 5 of 6, by Anonymous Freak
I have quite a few.
A Performa 630 DOS Compatible, a Power Macintosh 6100/66 DOS Compatible, and a boxed PCI "PC Compatibility Card"
You need the "PC Setup" system extension+control panel to make the DOS card work in any of them. Version 1.x were the original releases of the software by Apple. Version 2.0 was spun off to a separate company to sell, and had quite a few improvements. The seller of 2.0 made Version 2.1.7 free when shutting down - you can find perfectly legal copies of 2.1.7 online, including the serial number registered to "free". You need version 2.x to run a DOS card on Mac OS 8 or later. (Although there are no drivers for Mac OS X.)
Reply 6 of 6, by dr.zeissler
MacOS 8 needs PC-Setup 2.x ? Are you sure about that?
I use MacOS 8 on 6100/66 and PC-Setup 1.64.
