First post, by edwardo78
Hi all , i need help
i have an
Mac IIvx
that when i boot it on the screen go on and it's shows VGA sign but no picture is seen
i have replace all the caps on the board and its still the same
any one cane help ?
Reply 1 of 3, by Jo22
Hi, so it's a real computer?
If so, check the NVRAM/PRAM stuff.
Also make sure the battery is fine.
Some Macs won't run with a dead battery (no signs of life, no error mrssage).
And if a new battery is installed, they need a a reset of the aforementioned RAMs.
Reply 2 of 3, by edwardo78
Jo22 wrote on 2020-10-14, 06:37:
Hi, so it's a real computer? If so, check the NVRAM/PRAM stuff. Also make sure the battery is fine. Some Macs won't run with a d […]
HI
YES ITS A REAL COMPUTER
I HAVE A NEW BATTERY AND ALSO REPLACE ALL THE CAPS
ITS TORNES ON BUT WITH BLACK SCREEN WITH NO MASAGE
WHAT IS : need a a reset of the aforementioned RAMs ??
Reply 3 of 3, by Jo22
Oh. Did you try re-seating the chips already ?
Sometimes, the connection between sockets and chips got bad due to corrosion etc.
The normal DIL/DIP sockets are usually easy to work with.
PLC/PLCC/PGA and so on require lots of care or special tools.
Pulling chips from these sockets with a screwdriver will often destroy the sockets or pins.
