Fastest emulators period
Emulation of old consoles and arcades.
Re: Fastest emulators period
Postby noop » 2015-7-20 @ 18:53
Cyberdyne wrote:Come on guys somebody recommend a good DOS Atari 2600 emulator :P
I have an unfinished one lying around for 10+ years. Is there demand for a tiny 2600 emu with full speed on slow 486? :)
User avatar
noop
Postby mr_bigmouth_502 » 2015-7-20 @ 20:02
I don't have easy access to a 486 at the moment, but I would like to see it. I could probably try it out in PCem.
My NEW(ish) desktop:
User avatar
mr_bigmouth_502
Postby noop » 2015-7-20 @ 20:08
mr_bigmouth_502 wrote:I don't have easy access to a 486 at the moment, but I would like to see it. I could probably try it out in PCem.
I think I'll have to fix a few things and test on 386 or 486 myself. Have plenty of hardware lying around, just trying to find motivation to make something useful with it.
User avatar
noop
Postby leileilol » 2015-7-20 @ 22:07
I edited the OP XD
by the way, DOSBox is not for running Windows 9x
User avatar
leileilol
Postby mr_bigmouth_502 » 2015-7-21 @ 03:29
leileilol wrote:I edited the OP XD
Yeah, there's a pretty big difference between "fast" emulators and "accurate" emulators. Most emulators strive for the latter nowadays, though I kind of miss the charm the earlier emulators had.
User avatar
mr_bigmouth_502
Postby sliderider » 2015-7-24 @ 03:43
Stella
http://stella.sourceforge.net/
User avatar
sliderider
Postby noop » 2015-7-24 @ 23:12
Not sure about Stella's performance though..
Some quite fast emulators for DOS and windows are available here: http://emulators.com/download.htm
Atari 800 emu should work on 386
Would be interesting to measure performance for all emulators listed. What systems are really required to run some specific software at full speed.
For Megadrive, there is Genecyst. It is generally less precise then Kgen98 but could be faster.
User avatar
noop
Postby leileilol » 2015-7-25 @ 02:10
I thought Genecyst and Kgen98 ran mostly the same speed though Kgen had a slight edge for accuracy/compatibility. it also has a HORRIBLE time generating a lookup table on its first start though
User avatar
leileilol
Postby leileilol » 2015-8-13 @ 21:32
What I also want to do is measure which version of ZSNES (DOS) is fastest in 5 games in the default 8bpp resolution and with sound enabled
- Battletoads & Double Dragon
- Chrono Trigger
- Mario Kart for Mode7+DSP1
- Starfox, just the title screen and intro alone is enough for SuperFX performance. This is the Crysis
- Gradius III - just the Konami logo alone will kill the frames.
Measured on a 486 class processor... or a Pentium non-MMX.
EDIT: a bunch of preliminary testing led me favoring ZSNES 0.989 so far, it gets an almost consistent 30+fps on the Chrono Trigger intro sequence
User avatar
leileilol
Postby Maraakate » 2015-8-25 @ 04:23
Regarding Corn. Iirc that only either played demos or very barely was able to play mario64 but I can't remember 100% for sure. I do have all the binaries as far as I know archived from 10 years ago from zophar and the one n64 site that had a lot of compatibility stuff archived ( can't remember the name of the site, though I do remember it was a UK hosted site )
User avatar
Maraakate
Postby leileilol » 2015-8-25 @ 04:40
Waverace 64 could also be completed in Corn, except for one level which corrupts verts a bunch where it covers the screen. and the announcer gets a strange pitch shift
Back in 2000 I juggled between Corn, and some hacked up UltraHLE
User avatar
leileilol
Postby Maraakate » 2015-8-25 @ 04:46
User avatar
Maraakate
Postby kazblox » 2015-10-17 @ 20:32
Warajevo does pretty good for Spectrum emulation on a 386SX-33.
kazblox
Postby Stiletto » 2015-10-28 @ 22:19
kazblox wrote:Warajevo does pretty good for Spectrum emulation on a 386SX-33.
Actually, as leilei pointed out earlier, things like Warajevo, DosUAE and VICE are all off-topic since none are console or arcade emulators.
Thread cleanup: I guess I'll remove their mentions then, leilei? :)
do the Fandango!" - Queen
Stiletto
User avatar
Stiletto
Postby ratco » 2015-12-09 @ 14:31
Thanks for this thread. I have been preparing a game machine which consists of a pentium 1 133mhz (non-mmx) with 64mbs of ram. I am using FreeDos as OS. The machine is not really fast, so I am happy to get some ideas on fast/efficient emulators that can run well in this machine.
If I may ask, isn't genecyst supposed to be the faster mega drive emulator for older pcs?
Also, another thing: I have tried running the DOS version of no$gba, to play Need for Speed Most Wanted, and it plays terribly slow. But the readme file indicates a 486 as being usable. Does anyone know of any setting I might have to adjust, or some other emulator that can emulate GBA in Dos??
Thanks!
ratco
Postby Lo Wang » 2015-12-22 @ 23:38
TRS-32
"The CPU emulation is extremely accurate, supports all known instructions, and runs at exact TRS-80 speed. It is also extremely fast, being written in assembly language, and can exceed actual TRS-80 speed on any computer capable of running Windows"
User avatar
Lo Wang
Postby 386SX » 2016-8-15 @ 14:45
There was a Master system / Game gear native dos emulator that ran quiet "well" in a 486 and had also a PC Speaker sound output!
386SX
Postby dr.zeissler » 2019-6-28 @ 19:20
I am currently using a p200mmx and collecting some emulators that run games well.
CPU: PII 133-333 MOBO: SNI-D981 RAM: 512- FDD: Dualfloppy 3,5"HD/5,25"HD - 3,5"HD - 5,25"DD ISA-Catweasel HDD: 2x40GB - DVD
ISA(3): Audician32-S2Dreamblaster - GusACE PCI(3): Monster3D- Intel NW AGP(1): 3dfx V3-3000
dr.zeissler
Postby dr.zeissler » 2019-6-28 @ 20:31
I think I'll check this site out: http://coagulus.newport.net/c1/frlow.html
dr.zeissler
Postby realnc » 2019-6-29 @ 15:07
I can confirm that Callus was very fast. I was running it on a non-MMX Pentium1 133MHz to play Capcom games (Cadillacs & Dinosaurs, Street Fighter 2, Knights of the Round, etc) at full speed. It seemed like magic back then.
User avatar
realnc
PreviousNext
Return to Console & Arcade Emulation
Who is online
