Epsxe fps startup
Emulation of old consoles and arcades.
Epsxe fps startup
Postby emanuelect » 2017-7-20 @ 18:17
Every time I have to select the fps at startup of the game, how can I automatically start the game with the desired fps?
emanuelect
Re: fps startup
Postby Jorpho » 2017-7-20 @ 18:23
I know you have previously stated that you cannot speak English very well, but please realize that even if you wrote this post in your native language, no one would have any idea what you are talking about.
User avatar
Jorpho
Re: Epsxe fps startup
Postby emanuelect » 2017-7-20 @ 20:36
I set the game to 60 fps, but it start with 50 fps, i would like to start the game without fps's display with 60 fps.
emanuelect
Postby jxhicks » 2017-7-20 @ 22:55
Are you playing a PAL release of the game? If so that would be why it is defaulting to 50 fps.
User avatar
jxhicks
Postby emanuelect » 2017-7-21 @ 01:11
Yes, it's pal, but I'd like to play by default with 60
emanuelect
Postby jxhicks » 2017-7-21 @ 17:28
Well, PAL games don't run at 60fps, they run at 50. If you want it to play at 60 you'll need the NTSC version.
User avatar
jxhicks
Postby Qbix » 2017-9-13 @ 07:21
*closed for attracting spam 3 times a row*
Water flows down the stream
User avatar
Qbix
DOSBox Author
Return to Console & Arcade Emulation
Who is online
