locked files
First post, by Jiri
I have no control over exe. files in my mounted DOSBox games directory. When I want to move, rename, or delete a file, I always get the notice: It is being used by another person or program. Reboot or start into safe mode did not help. I found freeware utility "Freefile" which can find the processes that holds the lock but in my case it cannot find any process. Only help is another freeware utility "Move on Boot" that can delete a file during boot but it is an awkward solution because reboot is needed and the files must be added one by one (not entire directories) and I have lots of locked files in different directories. My system is Windows XP, the file system is FAT32. Has anybody an idea how could I get rid of this annoying problem?
Reply 1 of 16, by Jiri
I´ve initially thought it could be a DOSBox related problem but it is not. Now I found that affected are in fact .exe files for DOS also outside the DOSBox mounted directory (but not files for Windows) and that I cannot rename the file by using context menu, but it works with F2. I also cannot delete the file by pressing delete key, but drag and drop to the bin works. If I use context menu or press delete key, the file become immediately locked and I cannot use F2 for renaming or drag and drop to the bin until the next restart. Strange, but I think I can live with that.
Reply 5 of 16, by Jiri
taiken7 wrote:
Might be the anti-virus software -- every time Windows touches an .exe, your antivirus software grabs the handle and tests for v […]
your antivirus software grabs the handle and tests for viruses..
locking the file in the process.
(It might also be your file system NTFS/other?)
Thanks for suggestion. The file system is FAT32, and no, antivirus is not the cause (tried to disable it already). Now I know, that something is wrong with Windows Explorer. If I try to delete/rename locked file with Total Commander, it works, but only if no Windows Explorer window is open. So it is Windows Explorer that locks the files. It has been a while since I reinstalled Windows, so maybe it is needed. For the present I can handle the problematic files easily with Total Commander (not a big problem, since affected are only DOS .exe files) and I will see if there are any other problems.
Reply 6 of 16, by Markus
It seems to me, you have installed some strange shell-extension.
To verify, you should start regedit and look under HKCR\exefile\shellex.
Look for all the possible handlers that are listed there.
You will see only something like {86F19A00-42A0-1069-A2E9-08002B30309D}; look under HKCR\CLSID, what the handler is for.
But don't fiddle with them, unless you know, what you are doing...
Reply 7 of 16, by Jiri
Thank you, Markus, for your advice. I created a restore point, backed up the registry and deleted CmdLineExt in HKCR\exefile\shellex. And now everything seems to be working fine and the files are no longer locked. I am not sure, though, if I can safely let it deleted for good.
I have attached two screenshots of the registry to the System Specs forum, because for some strange reason it is impossible to attach files in this forum.
Topic 4421
Reply 8 of 16, by Markus
Hi Jiri,
there seem to be at least two versions of the dll: cmdlineext02.dll and cmdlineext03.dll, both are part of the securom-copyprotection, although they are not involved in the protection itself.
They extend the propertymenu of securom-protected executables by one entry named "Analyze launch", which shall provide some information for securoms supportline (just tried it: application refused to start at all and didn't write a logfile.)
If the dll is deleted, it will be recreated as soon as you're starting a protected application again; however it will not be recreated, if you remove all references in the registry (best done with regsvr32 /u cmdlineext0X.dll).
I didn't notice any differences with protected apps after removing this dll, they are working as they should.
Well, securom doesn't seem to think it's vital too, otherwise they wouldn't have chosen %TEMP% for the installation.
So I assume it's safe to get rid of this dll, but you can keep a copy somewhere in case you should need it (regsvr32 cmdlineext0X.dll et voilà!)
Reply 10 of 16, by Guest
Jiri , i have the same problem. It all started happening after i installed DOS Box. To be even worse the files that are getting locked are patches for some programs that i use. Now not only that i can not erase this patches , but they also not work properly ?!
I came to idea that it is connected with DOS box after i first noticed the locked file problem - than i also noticed that DOS box icon appeared in recently used programs on Win XP start menu (although i really didnt use it recently).
I went on and uninstalled DOS box but the problems remained. Two more things i must add -
first i fiddled with mount drives in Dos Box - so just maybe this changed some windows settings for good ?
second : The program that phisically locks the undeletable files is explorer.exe
So developers please help. Perhaps there is a way to restrore system settings to way they were before installing dos box?
Reply 11 of 16, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
DOSBOX does not do things like this. Thousands of people used it without any problem like that (even Jiri's problem was not caused by DOSBOX).
You had to do something else...
BTW: DOSBOX does not have any icon of its own. 😀 You probably see DOS icon which is normally in Windows.
In any case: what about doing what Jiri did?
Mirek
Reply 12 of 16, by DosFreak
This happens to me occasionally but I usually just end the explorer task, after reading another post of a user with the prob I investigated my own system and found that
{9869EFB4-18E9-11D3-A837-00104B9E30B5} in HKCR
references
cmdlineext03.dll
Looking around the net there seems to be various versions of cmdlineext so when scanning your system look for cmdlineext* and start from there.
Found this: http://file.net/process/cmdlineext03.dll.html
Just found this:
http://abates.tetrap.com/archives/2004/12/22/ … neext02dll.html
Hmmmm, Going to have to do some testing. If this is true we may need to go on the warpath if someone hasn't already....
Bumping for later research and inclusion into Deep Thought.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 13 of 16, by DosFreak
Possible trojan?
http://www.wilderssecurity.com/showthread.php … 2034#post422034
cmdlineext is compressed with Petite. Time to break out the decompression tools. 😁
Reply 14 of 16, by DosFreak
Ran into this problem again a couple of days ago and finally decided to track it down, here's my latest info so far:
Main game executable contains cmdlineextXX.dll file which attaches itself to Windows Explorer and will lock any 16bit file from being deleted.
.dll compressed using "petite" compression program used by malware programs.
.dll rumoured to cause higher explorer processor utilization.
.dll rumoured to cause explorer to hang.
16bit files can only be deleted by:
1. Booting another Operating System and deleting the files.
2. Ending the explorer task in Task Manager and then deleting the files that you want deleted from the Command Line.
To fix this issue simply end the Explorer task in Task Manager, open upon a command prompt using Task Manager and then delete the cmdlineextxx.dll file in your \Windows\System32 directory.
Deus Ex Invisible War
cmdlineext03.dll
Ion Launcher.exe
CD2 Game Disc
SecuROM 4.87.04.0138
Grand Theft Auto: Vice City
CMDLineExt02.dll
gta-vc.exe
DISC 1
SecuROM *new* v 4.84.69.0071
Hitman 2
cmdlineext02.dll
hitman2.exe
SecuROM new V 4.82.01.0017
Master of Orion 3
CMDLineExt02.dll
moo3.exe
DISC 1
SecuROM new v4.84.50.0030
Max Payne 2
cmdlineext03.dll
MaxPayne2.exe
SecuROM *new* V4.85.04.0018
Simpsons Hit & Run
cmdlineext03.dll
simpsons.exe
SecuROM 4.85.07.0027
Star Wars Battlefront
cmdlineext03.dll
battlefront.exe
DISC 1
Securom v5.03.06.0041
Star Wars Jedi Knight Jedi Academy
cmdlineext03.dll
jasp.exe
DISC 1
SecuROM *new* V 4.84.84.0020
Star Wars Knights of the Old Republic
cmdlineext03.dll
swkotor.exe
SecuROM 4.87.02.0030
Temple of Elemental Evil
cmdlineext03.dll
TOEE.EXE
SecuROM *new* V 4.84.84.0019
Thief Deadly Shadows
cmdlineext03.dll
T3.EXE
DISC 1
SecuROM v5.03.04.0034
Tribes Vengeance
cmdlineext03.dll
TV_CD_DVD.EXE
SecuROM 5.03.06.0031
Unreal Tournament 2004
cmdlineext03.dll
ut2004.exe
DISC 1
SecuROM v5.02.02.0033
DOESN'T CONTAIN cmdlineext
NOLF 2
Lord of the Rings Fellowship of the ring
Neverwinter Nights Hordes of the Underdark Expansion
It looks like it's safe to say that almost every SECUROM game contains this .dll, which can only be bypassed by cracking the executable BEFORE executing the game. (Executing the game installs the .dll).
I can't say if more recent versions of SECUROM install this .dll or not since I haven't bought a copyprotected game in oh.....about a 1+. Hmmm, I wonder why? 😀
I plan to write up the above in a more comprehensive article and search the net for lists of other SECUROM games and see if those versions contain this .dll or not. I'm also not sure if updated .dll's have this issued fixed or not. Obviously if you have 16bit programs and you work with them alot then you will be affected by this.
Reasons why I haven't bought a PC game in 1+ year:
1. Can't make backups, and to do so involves too much research.
2. Copy protection installing drivers, which I hate. Meaning I have to use cracks which means I can't use the latest update for a game.
3. .dll's such as the one above where I have to jump through hoops to delete files.
4. Copy protection drivers causing erratic CD drive behavior.
5. Recent games suck.
Reply 15 of 16, by DosFreak
Looks like this issue is still around. Amazing...
Right-click issue in Mass Effect v1.01 Update:
http://masseffect.bioware.com/forums/viewtopi … 43285&forum=127
Reply 16 of 16, by DosFreak
Also affects Windows 9x
Windows 98SE Unable to delete or rename MS-DOS .exe files.
