First post, by eL_PuSHeR
Moderator
- Moderator
Hello. I am beginning to see the same symptoms for people who have any ATi Rage based graphic card and they receive a "cannot create rendering..." error message trying to run DOSBox.
Setting the output=XXXXX under dosbox.conf doesn't work no matter the value specified.
SOLUTION:
Setting a ms-dos variable called SDL_VIDEODRIVER=windib may work for you. Be sure output=XXXX is set to surface (just in case). In order to set a variable you need to issue a SET command like this... SET SDL_VIDEODRIVER=windib.
Good luck.
PS - I feel I have to credit some people here, user222, DOSFreak, Snover, Qbix, MiniMax, etc... 😎
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
