NFS4 High Stakes IN WINDOWS XP
Files, FAQs, and other things to help you get your games running before you start asking questions.
Postby Mephisto » 2005-8-14 @ 00:56
I#ve been working for 3 days, but now i got it (i hope this is not a second
thread to this theme :blush: - i searched, but found nothing to compare
with this i write right now )
OK - lets get startet:
(ps: all the links are German, so you have to trust me)
What do you Need: (for the speed :-D)
1.) NFS4- High Stakes
2.) The Official Patch 4.5 (find it on some NFS-Sites or gamershell or google)
3.) The 3d Setup files from:
http://nfs2000.4players.de:1033/nfs4down_trn.php
Here you have to search for the "3D-Setup v.2" link - a popup with the download will show.
Extract the files to your /nfs/3dsetup Folder - and execute the reg file.
and at least:
4.) The Custom-made Setup:
http://nfs2000.4players.de:1033/board.php
Here you have to go to the NFS4 - Button- left from the "Forum" button - and search for the
Neues 3DSetup für NFS4:Brennender Asphalt text - in this part you click on "mehr" -link ,
and the "Zum Download" -link.
(u can use this link too - its the same,the only difference is, its a direct-link :
http://www.8ung.at/jimdiabolo/Files/Ins ... DSetup.zip )
After you downloaded this, extract the file and run it, when its installed,
you can run the new setup - and choose you Resolution & the new
DX-drivers; i think the new Setup changes the d3da.dll file or replaces it
Vóila - this should it be, you can now play nfs4 on Windows XP.
I dont remember now if the steps 2&3 are nessecarry, but it works with them too -and,
if i've forgott something then i will add it with an update - for now:
have a nice Play - and give me a feedback if the "Manual" worked for you,
or if i have made a Mistake somewhere.
PS: im using SP1 i dont know if this also works with SP2
User avatar
Mephisto
Return to Deep Thought
Who is online
