"CONFIG.NT not suitable"
Reply 20 of 20, by Nicht Sehr Gut
You'll probably need Vlad on this. Had you modified your CONFIG.NT file in any way?
If I were you, I would uninstall VDMSound completely, then reinstall to another directory (I tend to like the nice compliant 8+3 directory names like C:\Utils\Audio\VDMSound). This might be an OS-level problem. You didn't mention which OS you are running.
