First post, by Unregistered
I've been working with computers for 20 years now. In an attempt to change the icon for the .vlp file (that saves the VDMSound Launch Pad settings) I've changed the file association for this extension somehow and I can't get it working again. Isn't Windows great?
Re-installing VDMSound and the Launch Pad didn't work, manually associating the .VLP files with the VDMSRun.BAT en .PIF files didn't work either.
What do I need to associate the .VLP file with to make it clickable again so that I can use it as a shortcut to run the associated applications with VDMSound?
Frank
