First post, by Unregistered
I have a USB Precision 2 joystick, and am trying to get it to work with Descent 2.
I tested it on two computers.
One works fine. But it will only run in 320x200 without display problems, having a Voodoo 3 and all (and VESA emulation doesn't fix it).
The other detects the joystick - or the control panel does. VDMSound knows it exists. Descent 2 doesn't. This machine will, however, run 640x480 fine.
Both machines are running Windows XP. Both use the same version of VDMSound. And both times, the same joystick. And the version of Descent 2 is the same.
Any idea what differences can cause this bizarre play-up? And no, I strongly doubt the video cards are doing it. đ
