Reply 40 of 72, by MajorGrubert
- Member
wrote:About the only thing I can think of would be a program allowing direct hardware access (a no-no in XP) or a virus that doesn't work when in Safe Mode...that or Magic Radiation.
I have the same feeling about this. Some service or device driver is interfering with normal mouse and sound operation inside the NTVDM. In safe mode Windows loads only the essential drivers and services and you don't run into problems.
There is a list of usual things to look for in this cases: virus infection, anti-virus software, hardware test or hardware monitor utility (CPU temperature monitor, etc). I have never seen such programs interfere with the mouse, but VDMSound can be impaired by them.
Some of these programs are not easily located, but be sure to take a good look at the Add/Remove Programs utility in Control Panel, and remember to go to the Device Manager (under Control Panel, System), select "Show Hidden Devices" under the View menu and check the drivers that appear under the "Non-plug and play drivers" group.
Regards,
Major Grubert
Athlon 64 3200+/Asus K8V-X/1GB DDR400/GeForce FX 5700/SB Live! 5.1
