Some Ideas
First post, by DosFreak
Implement memory checker into VDMSound GUI? Mabye a check button that when pressed in the VDMSound GUI it would output a .txt file using the settings that you currently have configured?
Figure out a way to remove the MOUSE driver from NTVDM for more memory? It takes up about 12.5k. I've tried deleting the WOW mouse driver's but that didn't work...(of course..it's WOW DUH!)
Make your games work offline
Reply 1 of 2, by Snover
I'm sorry, I'm just not getting this. What, exactly, are you wanting?
Yes, it’s my fault.
Reply 2 of 2, by vladr
Yes, that was mant to be in the next LaunchPad anyway. 😀
I don't see much need as long as it loads into upper memory, but some sort of TSR remover should do the trick (messy, though, especially if NT expects MOUSE to be somehwere/use some shared data block).
V.
