First post, by yugioh47
HI there, is there any i can integrate vdmsound into windows xp?
Reply 1 of 3, by yugioh47
hi there here is an image that i've taken to show you that vdmsound isn't showing up on windows xp sp2.
https://www.dropbox.com/s/p9p8zauhqoep2 ... t.bmp?dl=0
this is when i've installed vdmsound 2.1.0 on windows xp sp2 also xp sp3 has the same problem
Reply 2 of 3, by collector
A couple of things.
First VDMS questions should be asked in the VDMS forum - www.vogons.org/viewforum.php?f=16 This forum is for Windows games and VDMS is for DOS games. Perhaps a mod would be so kind as to move it for you.
You have to have Launchpad installed for shell integration and it will only be seen in the context menu for DOS executables.
Lastly, consider using DOSBox instead. While VDMS will emulate the sound in an NT Windows you are using the NTVDM to emulate DOS. It is a very poor DOS emulator. It has poor compatibility with DOS games and will not shield you from timer bugs. DOSBox has much higher compatibility with DOS games and you can slow it down enough to avoid timer bugs.
The Sierra Help Pages -- New Sierra Game Installers -- Sierra Game Patches -- New Non-Sierra Game Installers
