First post, by Belgarath
- Newbie
hi there
i've been experimenting with vdmsound and i must say it's a godsend, this program is truly excellent and has solved most of my compatibility problems (especially with my "$"£%$" onboard sound)
but i run my games from a seperate gui, so running games from shortcuts is no good for me, now running dosdrv in a batch file works great for most but some games require special options, for instance betrayal at krondor requires emm memory, now this is simple via a shortcut but how can it be done from a command line? i think im right in saying the only command line switch is to load a ini file but examining the ini file and the help file has given me no clue on how to add this.
any help would be greatly appreciated
