First post, by Unregistered
I can't get anything to run, please help.
When using the launchpad it tells me it can't find the DosDrv.exe although the error message points directly to where it is located. I've tried uninstalling / reinstalling ect with the same deal. I have the update1 installed (copied over or whatever). I checked the troubleshooting FAQ and made sure that VDMSPATH or whatever the environment variable is called points to the right location and it does.
When using the right click (non-launcher) I get the autoexec.vdms is not suitable for this application ..
System Specs.
AMD Duron 800
Asus A7V Mobo
512MB Ram
Sound Blaster Live Value (not sure of the bois rom version or version of the board make)
Geforce2MX
ect ect ..
Tcalp
