11th hour
First post, by Adam
Well I'm having troubles with this game...
I have the win32 direct x thing and It plays but the sound is messed up.
I try it in dosbox and the sound works perfect but it runs slow and very annoying. Does anyone know how to get this to work?
and If I run it with VDMsound I get this error
check4MSCDEX: ---------------------------------------------------------
check4MSCDEX: data for drive A: follows
check4MSCDEX: door is closed and locked
check4MSCDEX: Supports only cooked reading
check4MSCDEX: Read only
check4MSCDEX: Data read only
check4MSCDEX: No interleaving
check4MSCDEX: prefetching is not supported
check4MSCDEX: No audio channel manipulation
check4MSCDEX: Supports HSG addressing mode
and if I run the directx patch with VDMsound it doesn't do anything
Reply 3 of 6, by eL_PuSHeR
There should be a .VLP shortcut file in the game folder. Right-click on it.
Moving to VDMSound, by the way...
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 4 of 6, by Adam
It really isn't a VDMSound problem... I'm just trying to get the game to work any method but each one somthing doesn't want to work right...
As for the properties of the VDMSound shortcut, I can't find any "cd-rom extensions option".
