First post, by Hazekel
- Member
Now this is weird. In trying to learn how to create a shortcut with VDMS (which I still don't understand), I saw that VDMS allegedly "will not work" with Windows programs. Well, I could not get the Windows only version of Jack Orlando Director's Cut to work because of sound problems, so not realizing that VDMS was for DOS only I tried it and resolved the problem (but only when starting from the Orlando Menu and not directly starting the game). Anyway, VDMS did the trick, which is why I am trying to create a shortcut to run JACKSTART.EXE using VDMS.
I would appreciate any help on this possible, but thought you would like to know that VDMS seems to be the only solution to this Windows only game (and I know for sure that this is not the old DOS version - which they did not convert into the Director's Cut).
DC
