First post, by Hazekel
Having not had success with DOSBOX for Terminator Rampage I tried to use VDMS but it keeps saying "needs 2 mb ems" despite the fact that I have setup in the VDMS shortcut config for 4 MB. I have also tried 8 MB of EMS but it keeps saying I need 2 MB. Why is it not recognizes the EMS?
Reply 1 of 4, by MiniMax
Rank Moderator
Moderator
Hazekel - have you checked that VMDSound/NTVDM gives you EMS? Can you launch COMMAND.COM, do a MEM /C and see if you have EMS?
_________________
Reply 2 of 4, by Hazekel
Umm, you mean in actual Windows? I know VDMS is not a true emulator but I thought it did something to get EMS. Windows does not use EMS (only XMS) but I thought VDMS did emulate EMS. If not, then how do I get EMS?
Thanks for the help.
Reply 3 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
vdmsound emulates sound. not ems.
so if you don't have ems without vdmsound then you have to use other methods.
dvwjr is experimenting with it. You might hope that he will take an interrest in your case.
Water flows down the stream
Reply 4 of 4, by MiniMax
Rank Moderator
Moderator
Hazekel - start here: http://www.nforcershq.com/forum/viewtopic.php?p=317966
Until dvwjr announces a better solution, try playing with the PIF-settings, and your on-board devices.
_________________
