First post, by supergod
hi.
the problem is, mouse is moving too slowly and when i try to fix it via mousectl line in *.bat file, no matter what values i set up, scrolling in the game starts to get kinda crazy. when i point the mouse to the upper end, screen starts to move up, down, up, down..
any ideas?
Reply 1 of 2, by SysGOD
hi,
i recommend you try running the game with dosbox 0.65 or newer 😉. under VDMS you can use the tool MOUSE2KV.EXE to speed up mouse sensitivity in SVGA games. it is located in the main VDMS directory. you should also read the mouse2kv.rtf file on how to use it.
