Originally posted by Unregistered Really i don't like the idea of installing and then booting to 98se when wanting to play oldgames...
Like I said, your options are limited. There are numerous games of mine I have yet to run properly in XP.
...(mirc's\icq's\httpd\ftpd\..) maybe i'll stop playing some games..
What do "mirc's\icq's\httpd\ftpd" have to do with not being able to run some DOS games?
Btw what causes this lag in keyboard response/stickykeys/refused response keys, it is common in doom also when i enable sound?
I don't know. You have to treat each game as an operating system. They all work differently, even when they appear to be the same.
In the case of DOOM, the game uses a PoPF instruction that normally does not work on a NT Operating System (this is why audio doesn't work on Windows NT 4 and 2000). For XP they implemented a "work-around" that allows it play with audio...poorly. If you run setup for DOOM and choose "No Sound FX" and "No Music", you would see that it runs smoothly.
As for "Witchaven", I have no idea. It uses the BUILD engine like Duke3D, but the setup program is completely different and Duke3D didn't have the keyboard problem.
Witchaven
And i didn't have any problems with the setup program?..
If you are still referring to Witchaven, then it is possible you have a re-release that was "fixed".
If so, try configuring it to it's lowest possible resolution, with no music or sound effects...Does it run properly?
Any ideas on how to slow pc? Airborne Ranger keeps speeding and quarantene also..
No good ideas, all the "slowdown" programs out there use a method that causes problems with general computer operation.
For Airborne Ranger, try DosBox. Be sure and read the README file that comes with it. You also might consider emulating the Commodore 64 or the Amiga versions. Much easier on the ears and eyes.
And anyone did manage to start Armored Fist over vdmsound?
System specifications for this say "386 DX-33 MHz or better", so it might also work in DosBox.
