Originally posted by Unregistered Well the disk version of Inherit The Earth runs (er, RAN) fine on my system as long as I chose "No Sound" for the digitized effects.
It turns out that my problem was the hacked installer crashing on my XP. Works ok so as long as I choose IGNORE after the first "16-bit subsystem error". Once I got past that it ran fine: SB16 digital audio withnOPL2 or MIDI. Not sure why yours is crashing.
I have a LOT of 3.5" disks lying around.
Start backing them up, either by ZIPping the files or imaging the disks. The life expectancy of floppies isn't very long.
With the CD issue, can't you just put it in the drive it expects? Or does it bug out as soon as it figures out you have more than one?
Bugs out. Where the CD is located is irrelevant. The code simply can't handle the presence of more than one CD drive...even when I've hidden it.
If you want, I can post my working 3.5" version up somewhere.
We try to avoid that. Tends to attract "warez leechers" and people from the ISDA who have a little too much free time on their hands.
I don't have a Microsoft mouse, but again, this worked previously and I haven't loaded any third party software. Just plugged the thing in and it's detected as a "PS/2 compatible mouse" with the Microsoft driver that comes with Windows XP.
This is optical I presume? I remember I had all kinds of erratic problems with my first MS optical mouse (although I had no idea it was the mouse at the time). Problems came and went, seemingly at random. Turn out the mouse was dying...it was just doing it over a long period of time. Problems went away the moment I hooked up a generic mouse I had lying around.
Last night I tried using it as a USB mouse and enabling USB Legacy Support in the BIOS, but same issue.
Well you shouldn't need "legacy support" unless you're trying to run it in "real" DOS.
Originally posted by HunterZ I count 3 things listed
Yes, but in the Metric system, that's 2 things.
Originally posted by Unregistered Since the configuration applications that try to detect hardware (including a mouse) freeze, I can't configure application to use or not use sound.
Do you have another mouse, any other mouse, that you can try with your PC?
Is there a good game with command-line parameters I should be using as a default to try and run with various options turned off?
Hrmm...Ms.PacEm has no mouse support, but it does autodetect... will look around...
Originally posted by Snover Is this a PS/2 or USB mouse?
USB with a PS2 adapter...he already covered that.
