First post, by Unregistered
Hey whats up everybody. First off my system specs are the follows:Windows XP, Compaq Presario laptop, 2.2 ghz, 512 MB, 32 MB Radeon graphics card. So here it goes. All Sierra games from the 80's and 90's (AGI and SCI) seem to crash after running the game for about 5 minutes. The games true MIDI sound is intact thanks to VDM sound. The graphics seem smooth also yet, my whole system will just automatically crash without giving my warning when playing these games. I have been able to play games such as kings quest and quest for glory using NAGI and FREESCI without the crashing, yet the sound just isnt the same compared to running the games with VDM sound at the DOS prompt(SIERRA.exe or KQ1.exe). I love the VDM sound program and I want to figure out why the games crash when not using the new interpreters such as NAGI and FREESCI. Does anybody have any suggestions?
Reply 2 of 7, by Nicht Sehr Gut
Originally posted by Unregistered The graphics seem smooth also yet, my whole system will just automatically crash without giving my warning when playing these games.
If your whole system is crashing, something is wrong well beyond the scope of the games.
I'd almost say you had something directly accessing your hardware (a no-no in XP), but it would prevent VDMSound from working and probably wouldn't crash your whole OS.
Honestly, this sounds like something nasty at the OS-level. You still have Compaq support?
Reply 3 of 7, by vladr
System could crash easily if direct-IO driver was running and the game(s) touched the SB hardware, triggering an IRQ that the sound driver may or may not be able to handle gracefully. MIDI and AdLib would work flawlessly, of course (AdLib conditional on having a real OPL chip on the soundcard, of course).
V.
Reply 4 of 7, by Nicht Sehr Gut
Originally posted by vladr System could crash easily if direct-IO driver was running and the game(s) touched the SB hardware, triggering an IRQ that the sound driver may or may not be able to handle gracefully.
But if this were the case (direct hardware access) wouldn't VDMSound fail to work at all? He said they ran OK, then crashed later...Hrmm...
Reply 5 of 7, by vladr
He mentioned that MIDI music was working fine, which may work with direct io in some cases. In any case, upon reading the original post again, I see it happens with games that don't necessarily use the SB (=> no IRQ's), so yeah, direct io is probably not the correct explanation. If these games onlyuse MIDI (not AdLib, no digitised sound effects) then I'd have to know more about the crash (BSOD? which DLL/.SYS?)
Reply 6 of 7, by Unregistered
The crashing occurs about 5 minutes into the games. I should also mention that its not vdm sounds complete fault. The games crash also just running them regularly at their dos prompts. I have new pc games(medal of honor) and emulator games(mame) and so forth that run flawlessy yet my computer doesnt seem to like these classic agi and sci games?
Reply 7 of 7, by Nicht Sehr Gut
Originally posted by Unregistered The crashing occurs about 5 minutes into the games. I should also mention that its not vdm sounds complete fault. The games crash also just running them regularly at their dos prompts.
That means it's not VDMSound at fault at all.
It sounds like the problem here is with DOS titles in general. Do you have any other DOS titles that you can try in XP?
One other thing to consider is that laptop displays work differently than a standard CRT. That could possibly be causing trouble as well. You might consider hooking the laptop up to a CRT and try playing the game on the CRT display and see if you still get these problems.
