getting vdms to work in vista
First post, by Patrick benatar
thanks,
i'll look into some XP drivers for vista, but dosbox.72 is running fine, that's why I don't quite understand entirely why VDMS doesn't run in fullscreen.
I will look into the dosbox instructions to find out about running loadfix, and also, I get no response at all when I hit ctrl f10 for the "keymapper" what ever that is, I seem to have found that the \ key is esc in dosbox on my laptop, but when i hit it it works like return, starting a new line making me unable to enter addresses, and the basic command for keymapper does not respond.
If you respond to this post here, i will see your response in future and reply in another thread, I posted here because it is literally called M & M 2 and that is the only game out of thousands so far that I have seen mention TSRs, thanks for your advice I will probably speak to you or the others in future about more queries.
P.S if you leave a link to where you want this sort of question I will go there, I get a little lost on forums like these. And programs like dosbox.
Reply 1 of 13, by keropi
Vista does not allow programs that take control of the hardware to go full-screen. Only programs that use DirectX or OpenGL as a rendering surface can go full screen... Even vista's own command prompt cannot go fullscreen... I am afraid there is no workaround for this, at least not one that I know that does not have weird side-effects/probs
Reply 3 of 13, by Patrick benatar
Thanks el pusher, for moving this somewhere appropriate I did mean sound,
keropi, based on what you are saying will Dosfreak's instructions to install graphics card drivers for XP work in allowing vdms and plain dos programs to run?
I have an ATI mobility Radeon HD 3470.
Based on my understanding of what Dosfreak said, I am downloading the XP version ATI Catalyst display driver and the WDM integrated driver from:
http://support.amd.com/us/gpudownload/windows … 15&lang=English
If i install these XP drivers into my vista system will VDMS and dos enabled programs work without the "cannot run in fullscreen" error?
And when you say vista "does not allow" do you mean based on the infuriating User Account Control? i disabled that, or do you mean in general?
I installed a non pirated version of Deus ex invisible war and when i tried to run it, windows said there was a conflict with disc emulation software and it would not run it, yet any software installed was straight out of the box from ASUS, when I finally discovered how to disable UAC, the game ran just fine, based on that, I am fairly cynical about what vista can and cannot do until UaC has been kneecapped.
Reply 4 of 13, by gidierre
all true, but I use dosdrv.exe fom command line under Vista and vdmsound works for me with no fullscreen crash.
We often forgive those who bore us, but we cannot forgive those whom we bore. (La Rochefoucauld)
Reply 5 of 13, by DosFreak
Yes installing XP video drivers in Vista will allow you to run a full screen command prompt with the potential loss of stability and the loss of DX10 and aero desktop.
As for Deus Ex IW you'll likely need to use a NOCD patch.
Make your games work offline
Reply 6 of 13, by Patrick benatar
Thanks both, for the advice, Deus ex IW runs okay in vista, it just needed UAC to be removed for some bizarre reason, but it does still crash occasionally, um, most pertinent question - it seemed to me a couple of years ago when I was last able to use VDMS that some games would only work with it, and not with dosbox, is this so? or can dosbox run any program VDMS can with the right configuration?
Dosfreak, I installed the files I specified in previous posts on this thread, they install themselves, I didn't put them anywhere, and I still can't run dos programs in fullscreen, or VDMS at all, am I doing something wrong? Anyone have any advice? Im not really that tech savvy.
P.S which is the best thread to post in for direct questions about running particular games in Vista? I have a lot of questions about games that I haven't yet found solutions for online....
Reply 7 of 13, by MiniMax
Rank Moderator
Moderator
DOSBox *is* much slower than VDMSound. So 4-5 years ago DOSBox were simply too slow for many games. But since then DOSBox has improved, it has got the dynamic core, and equally important, your PC has become 3 times as fast. So today DOSBox is the better solution. It is not perfect, but better.
_________________
Reply 8 of 13, by gidierre
Patrick benatar wrote:
...and I still can't run dos programs in fullscreen, or VDMS at all, am I doing something wrong? Anyone have any advice? Im not really that tech savvy.
fullscreen:
talking about vista, this is precisely why as I wrote I'm using dosdrv from command line
best thread:
well, I guess the windows section unless strictly dosbox related, in which case, dosbox games/apps.
Reply 9 of 13, by DosFreak
VDMSound doesn't run games, NTVDM does.
DOSBox can run far more programs than NTVDM can.
If you insist on using the command prompt in Windows Vista to run games then all you need to do is install the Windows XP drivers for your video card if your card has Windows XP drivers. More than likely you'll have to install the video card drivers through Device Manager since the installer that comes with the drivers may not like Windows Vista.
Probably the DOS or Windows threads under the Heading "The Guide".
Reply 10 of 13, by Patrick benatar
thanks again, I'm going to try some of the advice you've all given, but none of you quite answered what I was asking, I know dosbox is more powerful and that it runs many more games, what I'm asking is can it run all of the games that VDMS can run, are there any games that must be run with VDMS and can't be run with dosbox?
Reply 11 of 13, by MiniMax
Rank Moderator
Moderator
Yes.
_________________
Reply 12 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
Yes.
The real question would be if you want to run those games. (e.g own them)
Water flows down the stream
