Can't install
First post, by Unregistered
I fail at the first hurdle. Running the installer results in an error message "program too big to fit in memory".
According to mem/c I've got 614k free conventional memory, 74.5k free upper memory, 0k free extended memory, and ~940k free XMS memory.
I can't find any info wrt the actual memory requirements so could someone enlighten me please?
Thanks in advance
Mike
Reply 2 of 9, by DosFreak
Also are you sure that the game executable is not corrupted? That error is usually a sign that it is.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 4 of 9, by Unregistered
I'm having the same problem. I downloaded VDMSound (tried 2.0.4 and 2.0.3) and when trying to install, the command prompt box pops open for half a second then closes. When I unchecked the "close on exit" box and try it, I get that same message - "Program is too big to fit in memory". I've tried everything I could think of to solve the problem like, maxing all the values in the memory tab and copying autoexec.nt/config.nt to the folder (created custom config) to no avail.
1.4 Athlon XP 1600+
256 DDR
GeForce2
WinXP Home
On board sound (Soundmax drivers)
Reply 6 of 9, by vladr
Hmm, no command prompt is supposed to pop up. Obviosuly Windows thinks that you are dealing with an MS-DOS .exe file when in fact it's a .msi file.
Open up a command prompt and type:
msiexec
What happens? If a dialog box pops up, then what version is the dialog box reporting?
V.
Reply 7 of 9, by Unregistered
Thanks for the replies. 😀 I typed msiexec in the command prompt and I get a "Windows Installer" application pop-up with an OK button that says "Incorrect command line parameters. Windows installer V 2.00.2600.0. Portions of this software are based on the work of the Independent JPEG Group". Probably did'nt need that last bit but I figured what the heck hehe.
The wierd thing is, I downloaded the msi installer too but when I clicked it, nothing happened - might have been corrupted or something. Guess I'll try downloading it again.
Thanks again. 😀
Reply 8 of 9, by Nicht Sehr Gut
Snover wrote:
You need the MSI installer program for MSI support. I'm not sure why it wouldn't have been preinstalled along with Windows XP...
This never happened on my XP home. Hrmm.
