First post, by Parasite X
Ok heres my problem DosBox runs the game too sloooow and VDMSound runs it to fast but its very stable. Ive tested speedset and and moslo v1.32 but they dont work. If anyone knows of a good app that can be run on WiXP with VDMSound then plz add an link to where i can get it.
Reply 3 of 7, by MiniMax
Rank Moderator
Moderator
> Where do i find this option??
With VDMSound v. 0.0.0.0.1 you had to use a screwdriver and open up your PC. Then you had to physically remove the third resitor from the left, for the option to appear. In version 7387.6 it will probably be integration into the O-Magic-Thing-Cap interface, so you will just have to think about the option and it will appear.
Since you do not tell us which version of VDMSound you use, it is hard to tell you where *you* can find this option.
_________________
