First post, by DosFreak
- l33t++
Implement memory checker into VDMSound GUI? Mabye a check button that when pressed in the VDMSound GUI it would output a .txt file using the settings that you currently have configured?
Figure out a way to remove the MOUSE driver from NTVDM for more memory? It takes up about 12.5k. I've tried deleting the WOW mouse driver's but that didn't work...(of course..it's WOW DUH!)
