First post, by Guest
I've tried to play the old adventure Harvester, and the game starts ok, but when I try to start a game it says "insert cd 1", but I already have the cd inside.
My game cd is in drive H so I suppose that might be the problem. But how can I get it to recognise the cd in the correct drive. I've tried SAPUCDEX and of course enabling CD-ROM support (MSCDEX) but neither worked.
It works fine in DOSBox but is unplayably slow, so why do I get this cd error in VDMSound?
Any help would be great thanks.
Edit: Problem solved, I simply put the cd in my other (G:\) drive and edited the CONFIG.INI accordingly and it worked.
Reply 1 of 1, by Mierdamakus
Excuse me, how you edit the config? which parametres must I write? I try to play with DosBox and it doesn't recognize CD2, so if you could tell me how to play it with VDMSound, please.... Thanks a lot.
