dos path
Having problems with a specific game or application? Post your problems here!
dos path
Postby magboy » 2011-3-11 @ 09:42
I'm getting a DOS error 3 (path not found) in a database program. I run the path command and the path is correctly showing. anyone had this issue or knows of the fix? :cool:
magboy
Re: dos path
Postby Qbix » 2011-3-11 @ 09:47
path not found is using the current layout of your harddrives: it expects files to be in a certain directory.
It has not nothing to do with the path command itself.
Water flows down the stream
User avatar
Qbix
DOSBox Author
Re: dos path
Postby magboy » 2011-3-11 @ 10:24
I mention the path command only to state that the path is correct, the prog is looking for "y:\db\dbfiles\" and is not finding it. The mount was made in the same folder "y:\db\dbfiles\".
magboy
Re: dos path
Postby Qbix » 2011-3-11 @ 10:26
the mount is wrong.
you'd probably want mount y y:\
*moving this topic to dosbox. as this has nothing to do with vdmsound*
User avatar
Qbix
DOSBox Author
Re: dos path
Postby magboy » 2011-3-11 @ 10:33
Thanx, that solved the issue.
magboy
Return to DOSBox Games/Apps
Who is online
