First post, by Zorbid
The launch pad fails to create the temporary shortcut to
c:\disque_d\jeux\aventure\little big adventure\little big adventure\lba.exe
Changing both 'little big adventure' to 'lba' solved the problem.
Reply 1 of 8, by Snover
I'm not certain that's Launchpad, as there are other things that exhibit the same behaviour.
Yes, it’s my fault.
Reply 2 of 8, by vladr
That should have been fixed in LaunchPad 1.0.0.7 (all filenames are converted to 8.3). Unless, that is, you are using NTFS and chose to disable 8.3 (DOS) filename support. To check, simply type the following at a command prompt:
dir /x "c:\disque_d\jeux\aventure\little*"
...and you should see something like:
xx-xx-xxxx  xx:xxx      <DIR>          [b]LITTLE~1[/b]        little big adventure
What's important to see there is the "LITTLE~1" entry. If it isn't there than LaunchPad can't do anything about it. If it is and you are using LaunchPad 1.0.0.7 (version is in "Advanced properties" in the bottom left corner for 1.0.0.7) then I'll have to take another look at the code.
V.
Reply 3 of 8, by Sid
Ok, I went to dos prompt and tried it, no 8.3 support it seems, although I tried on a fat32 partition. I also got those problems with launchpad (not able to find the .pif), any suggestions how to activate 8.3-support?
Reply 4 of 8, by vladr
Problem fixed (worked around) in LaunchPad 1.0.0.9 (not yet uploaded to http://vdmsound.sourceforge.net/files/ yet).
V.
Reply 5 of 8, by Snover
Vlad. Perfect time for UNIFICATION.
Do it.
Do it now.
Do it now or I'll rip your eyeballs out and feed them to my pirahnas.
Yes, it’s my fault.
Reply 6 of 8, by Stiletto
Hey Zorbid - read this! 😀
showthread.php?s=&threadid=226
do the Fandango!" - Queen
Stiletto
Reply 7 of 8, by Nicht Sehr Gut
Originally posted by Snover Do it now or I'll rip your eyeballs out and feed them to my piranhas.
Vlad. If you receive an email attachment named rippinghands.zip ...DON'T open it.
Reply 8 of 8, by Snover
Actually, rippinghands.zip wouldn't be a problem. rippinghands.zip.vbs, on the other hand...😉;)
Yes, it’s my fault.
