Reply 21 of 21, by Kaminari
Qbix wrote:
you tried the cvs of dosbox ? if it still doesn't work with intelligent=true then it might be a bug and you should contact srecko or me.
Sorry to revive this thread which is half-related to DOSBox, this is just to remind that MIDI still doesn't work in Touché if intelligent mode is enabled (tried it in latest Ykhwong's build).
