Reply 120 of 208, by caceresmartin2000
thanx for the fast reply!
Did you change to your VDMSound directory before starting VDMSound? Presuming you did, what messages did you see appear on the command line? Did you see a "Tip of the Day" error window pop up?
yes, i change to the vdmsound directory.
When i execute dosdrv.bat i see on screen:
c:\vdmsound> vxdsload
c:\vdmsound> vxdsinit
and then appear the pop up about the tip of the day........
....the initialization process will now continue.
Note that Ms.Pac-Em will default to speaker sound (and stay that way) if it doesn't detect a SoundBlaster when it's first run. To be sure, go into the options portion of the menu and try to switch it from "PC Speaker" to "SoundBlaster" each time.
About the game i'm running is not "Ms.Pac-Em". I was refering to pinball dream 2.
That's going to depend on the circumstances. I'm guessing that you're referring to VDMSound here; in most bases you can leave it set to the default (SoundBlaster 16). Occasionally, you might need to override it with another choice.
the question is wich soundblaster i have to select in setsound, soundblaster 16?
Have you tried using the "real-mode" DOS driver?
by the way i try with the dos driver (thanx for the tip) and it worked for pinball dreams 2, but no luck with pinball dream and with 3dvcr.
