Sound and Video Delays
Reply 40 of 62, by Glidos
Neither are supposed to need repeated unlocking, but they both key on the same system information, so if one has the problem so will the other.
How is the machine connected to the interent? Its probably information on the network config that's changing. A few people have had problems under XP, but that was usually just two different IDs, one when on line one when off.
Reply 41 of 62, by laracroft.net
I'm permanently (that is, when my computer's on, of course) connected to the Internet via French ISP Free's Freebox v4 (an ADSL2+ modem), which my computer is linked to by Ethernet cable.
"I'm not interrupting, am I?" -Lara Croft, Tomb Raider - Adventures of Lara Croft
Reply 42 of 62, by Glidos
Ethernet shouldn't cause this problem. Try running this. Might help track down the problem
Reply 43 of 62, by 2007Jenn
Hi there,
I am having similar problems with having to continually unlock both Glidos and VDOS32 and the sound is flaky at best.
Here is some background (please let me know if you need more) info. I recently purchased a new laptop and it had Vista Home Premium 32 bit installed. I didn't install VDMS because as I understood it wasn't needed - however, I did install Glidos and VDOS 32.
I am having the same sound problems as the OP - the background noises (boots walking / running, shooting, enemy noises, etc) and the FMV's all have sluggish, crackly, intermittent sound.
My second problem is that despite having purchased Glidos, I still get the spinning logo on the start menu and levels 3 - the end. Also, VDOS32 needs to be unlocked every time I reboot my PC. Though it’s not quite as annoying as Glidos, since as of now s does not need to have codes entered. I am assuming the two are related?? I am connected to the internet via an Ethernet connection to cable broadband (not too sure if that matters?). Also – I seem to have different Glidos ID's each time I restart my PC.
Finally - all of the FMV's play in very, very small screens. Not as big an issue as the others - but worth a mention.
Sorry for all of these problems. What I really should be going on about is how awesome a programme VDOS32 / Glidos is! Thanks so much for developing it. I don't think that I would have ever seen TR1 again without it 😀 I can imagine it took a lot of effort as well.
Thanks again!
Reply 44 of 62, by Glidos
Its at least a good sign that you are seeing exactly the same problems. Difficult to fix though at the moment. I have only 64bit Vista here, and VDos32 doesn't work at all yet with that.
But don't give up hope, I should be able to get it fixed eventually.
Try out the app I mentioned in the earlier message. It might give us some info.
Reply 45 of 62, by laracroft.net
Hi 2007Jenn!
As we would say back here: Bienvenue au club! :-)
It's actually good to hear from somebody who has the same problems (not in the gloomy sense though, rather because we're all trying to get the same thing working: TR1!).
Glidos, I've run DispHost and attached the resulting snapshot to this post. (I run it twice just in case, seconds apart, and NIC2 changed, so maybe that was a good idea, and then again maybe it's supposed to change.)
Reply 46 of 62, by Glidos
NIC2 is an old method no longer used. Its NIC3 that's important. Can you try again after a reboot to see if that causes NIC3 to change?
Cheers,
Paul
Reply 47 of 62, by 2007Jenn
Hi again,
Yes - I was actually glad to see that someone had the same problem as well 😀
Here is what I got:
Reply 48 of 62, by 2007Jenn
Sorry- hit the wrong key! Here it is: -
Reply 49 of 62, by 2007Jenn
Ran it again: -
Reply 50 of 62, by 2007Jenn
I don't know if this helps or not - but I ran the diagnose programme from: http://www.tombraiderforums.com/announcement.php?f=15
It tells you more than you ever wanted to know about my PC!
Diagnostic tool developed for www.tombraiderforums.com
Version : 2.22
Author : Simulation
Select All then Copy and paste the text in Notepad into a reply on the forum.
Operating System
Windows Vista Detected
[b]COMMAND.COM[/b]
COMMAND.COM has been installed
[b]Autoexec.NT [/b]
@echo off
lh %SystemRoot%\system32\mscdexnt.exe
lh %SystemRoot%\system32\redir
lh %SystemRoot%\system32\dosx
SET BLASTER=A220 I5 D1 P330 T3
[b]Config.NT[/b]
dos=high, umb
device=%SystemRoot%\system32\himem.sys
files=40
[b]Programs Currently Running[/b]
Image Name PID Session Name Session# Mem Usage
System Idle Process 0 Services 0 28 K
System 4 Services 0 12,172 K
smss.exe 400 Services 0 536 K
csrss.exe 532 Services 0 4,588 K
wininit.exe 596 Services 0 3,216 K
csrss.exe 604 Console 1 10,652 K
services.exe 640 Services 0 5,536 K
lsass.exe 652 Services 0 6,952 K
lsm.exe 660 Services 0 4,208 K
winlogon.exe 764 Console 1 4,552 K
svchost.exe 852 Services 0 5,712 K
svchost.exe 932 Services 0 6,600 K
svchost.exe 1036 Services 0 8,560 K
svchost.exe 1064 Services 0 52,548 K
svchost.exe 1080 Services 0 18,732 K
audiodg.exe 1216 Services 0 11,176 K
SLsvc.exe 1256 Services 0 3,740 K
svchost.exe 1312 Services 0 10,272 K
svchost.exe 1496 Services 0 10,436 K
spoolsv.exe 1708 Services 0 8,184 K
svchost.exe 1732 Services 0 10,492 K
svchost.exe 2012 Services 0 3,396 K
HWAPI.exe 292 Services 0 4,396 K
mcmscsvc.exe 520 Services 0 1,908 K
McNASvc.exe 656 Services 0 9,452 K
mcods.exe 1340 Services 0 256 K
mcpromgr.exe 1580 Services 0 3,564 K
McProxy.exe 1824 Services 0 10,256 K
RedirSvc.exe 1024 Services 0 5,500 K
Mcshield.exe 1380 Services 0 15,112 K
mcsysmon.exe 804 Services 0 3,328 K
mdm.exe 2064 Services 0 3,592 K
MpfSrv.exe 2112 Services 0 5,008 K
mps.exe 2192 Services 0 2,096 K
msksrver.exe 2220 Services 0 3,776 K
svchost.exe 2384 Services 0 3,788 K
PSIService.exe 2424 Services 0 4,764 K
RoxWatch9.exe 2520 Services 0 5,680 K
stacsv.exe 2664 Services 0 4,348 K
Show last 64 lines
svchost.exe                 2820 Services                0      5,396 K
TRAISVCS.EXE 2840 Services 0 4,008 K
svchost.exe 2892 Services 0 1,948 K
SearchIndexer.exe 2916 Services 0 10,884 K
XAudio.exe 2992 Services 0 2,092 K
WUDFHost.exe 3116 Services 0 4,424 K
RoxMediaDB9.exe 3236 Services 0 13,012 K
taskeng.exe 3288 Services 0 4,352 K
dwm.exe 2340 Console 1 82,648 K
explorer.exe 1992 Console 1 48,120 K
SynTPEnh.exe 3480 Console 1 3,720 K
rundll32.exe 3568 Console 1 4,832 K
jusched.exe 3984 Console 1 3,156 K
sttray.exe 1488 Console 1 5,548 K
issch.exe 3844 Console 1 2,732 K
RoxWatchTray9.exe 2956 Console 1 8,180 K
DrgToDsc.exe 3920 Console 1 7,660 K
mpsevh.exe 980 Console 1 1,584 K
mskagent.exe 4036 Console 1 6,156 K
mcagent.exe 4088 Console 1 2,392 K
GoogleDesktop.exe 828 Console 1 2,152 K
PCMService.exe 2020 Console 1 314,776 K
gnotify.exe 1164 Console 1 10,228 K
GoogleDesktopIndex.exe 3936 Console 1 7,036 K
taskeng.exe 1152 Console 1 11,076 K
Kmaestro.exe 4152 Console 1 4,796 K
Apoint.exe 4188 Console 1 5,844 K
iTunesHelper.exe 4316 Console 1 5,004 K
GrooveMonitor.exe 4348 Console 1 7,016 K
sidebar.exe 4388 Console 1 24,876 K
DSAgnt.exe 4408 Console 1 9,224 K
ehtray.exe 4444 Console 1 2,064 K
wmpnscfg.exe 4452 Console 1 4,936 K
BTTray.exe 4532 Console 1 8,240 K
DLG.exe 4544 Console 1 4,652 K
quickset.exe 4592 Console 1 8,856 K
SetPoint.exe 4696 Console 1 8,012 K
GoogleDesktopDisplay.exe 4720 Console 1 6,440 K
ehmsas.exe 4920 Console 1 4,976 K
wmpnetwk.exe 4976 Services 0 9,228 K
iPodService.exe 5168 Services 0 4,736 K
WinMail.exe 5180 Console 1 11,620 K
GoogleDesktopCrawl.exe 5300 Console 1 3,488 K
sidebar.exe 5396 Console 1 15,440 K
KHALMNPR.exe 5444 Console 1 5,328 K
BTStackServer.exe 5620 Console 1 11,224 K
ApMsgFwd.exe 5924 Console 1 2,728 K
ApntEx.exe 6080 Console 1 4,220 K
CPSHelpRunner.exe 4572 Console 1 4,460 K
Glidos.exe 5296 Console 1 43,864 K
firefox.exe 3724 Console 1 79,276 K
WINZIP32.EXE 5092 Console 1 18,964 K
WINWORD.EXE 5740 Console 1 43,960 K
Corel Paint Shop Pro Phot 5660 Console 1 100,788 K
SearchProtocolHost.exe 5808 Services 0 8,488 K
SearchFilterHost.exe 5040 Services 0 4,708 K
dllhost.exe 2512 Console 1 4,204 K
dllhost.exe 5772 Services 0 3,764 K
diagnose.exe 3204 Console 1 7,872 K
ns2FCB.tmp 5072 Console 1 4,576 K
cmd.exe 5212 Console 1 2,192 K
tasklist.exe 2324 Console 1 6,404 K
WmiPrvSE.exe 4020 Services 0 5,808 K
System Event Log - Warning and Errors Only (last 24hrs)
Event Log from 08:00am on the 02/05/2007
Tomb Raider Game Setup Information
[b]Tomb Raider 1 Installed[/b]
TOMB.EXE File Size = 873739 bytes - Glide Emulator version installed by ATR Installer
[b]trai.dat[/b]
[TRUB]
TRAIVersion=1.0.6.92
OpticalDevice=E:\
UseGlidos=True
GlidosFolder=C:\Program Files\Glidos\
UseDgVoodoo=False
DgVoodooVersion=Not configured
DgVoodooVDDMode=Not configured
UseVDMSound=True
VDMSoundVersion=2.1.0
VDMSoundFolder=C:\Program Files\VDMSound\
VDMSoundType=Stereo
VDMSoundIRQ=7
SetAffinity=True
DesktopShortcut=Not configured
PifShortcut=C:\TOMBRAID\TOMBUB.PIF
[TR1]
OpticalDevice=E:\
UseGlidos=False
UseDgVoodoo=True
DgVoodooVersion=140
UseVDMSound=True
VDMSoundType=Stereo
VDMSoundIRQ=7
SetAffinity=True
DesktopShortcut=Tomb Raider (Glide).VLP
PifShortcut=Not configured
IdlePriority=50
VDDMode=False
[b]hmiset.cfg[/b]
[DIGITAL]
DeviceName = Sound Blaster 16/AWE32
DeviceIRQ = 7
DeviceDMA = 1
DevicePort = 0x220
DeviceID = 0xe016
[MIDI]
DeviceName = No MIDI Device
DevicePort = 0xffffffff
DeviceID = 0xffffffff
[b]NTVDM.EXE .COM[/b]
NTVDM.EXE has been installed
[b]VDMSound[/b]
VDMSound is not installed
[b]VLP Files on Desktop[/b]
Show last 55 lines
VLP files are NOT present on Desktop
[b]VLP Files in C:\TOMBRAID[/b]
[b]tomb.vlp[/b]
[program]
workdir=C:\Tombraid
params=
executable=C:\Tombraid\TOMB.EXE
icon=C:\TOMBRAID\tr1.ico,0
[winnt.pmode]
useCLIPOPF=no
[winnt.dos]
autoexec=c:\tombraid\sapucdex.exe
useAutoexec=yes
[vdms.midi]
sysExLed=Scroll Lock
[winnt.dosbox]
exitClose=yes
[vdms.gameport]
enabled=no
[winnt.storage]
useCDROM=yes
[winnt.scheduling]
detectIdle=yes
idlePrio=50
compatHWEmu=yes
[vdms.sb.fm]
enabled=no
[winnt.video]
useVESA=yes
[b]Tomb Raider 1 Gold - Unfinished Business Installed[/b]
TOMBUB.EXE File Size = 867563 bytes - Glide Emulator version installed
[b]Tomb Raider II Installed[/b]
Installed in C:\Program Files\Core Design\Tomb Raider II
Compatibility Layer Enabled = WIN98
Tomb2.exe File Size = 912896 bytes - Tomb Raider Patch v1.1 - Core Design
C:\Program Files\Core Design\Tomb Raider II\winplay.dll - Version 2.0.0.6
C:\Windows\System32\winplay.dll - Version 2.0.0.12
C:\Program Files\Core Design\Tomb Raider II\winstr.dll - Version 2.0.0.4
C:\Windows\System32\winstr.dll - Version 2.0.0.13
[b]Tomb Raider - The Last Revelation Installed[/b]
Installed in C:\Program Files\Core Design\Tomb Raider - The Last Revelation
Compatibility Layer Disabled
TOMB4.EXE File Size = 790528 bytes - TombRaiderChronicles XP Version - Speed Loader
DirectX Diagnostics Report
System Information
Time of this report: 5/3/2007, 21:26:19
Machine name: SWIRL
Operating System: Windows Vista™ Home Premium (6.0, Build 6000) (6000.vista_rtm.061101-2205)
Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
System Model: MP061
BIOS: Phoenix ROM BIOS PLUS Version 1.10 A06
Processor: Intel(R) Core(TM)2 CPU T7200 @ 2.00GHz (2 CPUs), ~2.0GHz
Memory: 2046MB RAM
Page File: 1738MB used, 2573MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 10
DX Setup Parameters: Not found
DxDiag Version: 6.00.6000.16386 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce Go 7900 GS
Manufacturer: NVIDIA
Chip type: GeForce Go 7900 GS
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0298&SUBSYS_019B1028&REV_A1
Display Memory: 520 MB
Dedicated Memory: 248 MB
Shared Memory: 271 MB
Current Mode: 1920 x 1200 (32 bit) (60Hz)
Monitor: Generic PnP Monitor
Driver Name: nvd3dum.dll
Driver Version: 7.15.0010.9746 (English)
DDI Version: 9Ex
Driver Attributes: Final Retail
Driver Date/Size: 12/14/2006 00:16:38, 3055616 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B71E3E-41D8-11CF-8A55-912101C2CA35}
Vendor ID: 0x10DE
Device ID: 0x0298
Show last 742 lines
        SubSys ID: 0x019B1028
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_B ModeVC1_A ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (SigmaTel High Definition Audio CODEC)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_8384&DEV_7690&SUBSYS_102801CD&REV_1022
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: stwrt.sys
Driver Version: 6.10.5290.0000 (English)
WHQL Logo'd: n/a
Date and Size: 12/1/2006 22:40:46, 647680 bytes
Other Files:
Driver Provider: SigmaTel
HW Accel Level: Basic
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Digital Output Device (SPDIF) (SigmaTel High Definition Audio CODEC)
Default Sound Playback: No
Default Voice Playback: No
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
Sound Capture Devices
Description: Microphone / Line In (SigmaTel High Definition Audio CODEC)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x0
Format Flags: 0x0
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Bluetooth Mouse
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xB004
FF Driver: n/a
Device Name: Bluetooth Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xB308
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Bluetooth Remote Control HID Device
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0xFFFE, 0xFFFE
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x27CA
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 2/8/2007 00:50:35, 191488 bytes
| Driver: usbd.sys, 2/8/2007 00:50:35, 5888 bytes
Gameport Devices
PS/2 Devices
+ PS2 KeyMaestro Multimedia Keyboard (x86)
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: Maestro1.sys, 6/14/2006 19:06:20, 7952 bytes
| Driver: SetupKey.exe, 11/8/2006 10:00:08, 86016 bytes
| Driver: RunSetup.dll, 11/7/2006 11:57:56, 49152 bytes
| Driver: Translat.inc, 7/18/2006 16:01:12, 76001 bytes
| Driver: HidKeybd.dll, 10/27/2006 10:22:08, 20009 bytes
| Driver: Kmaestro.exe, 11/3/2006 10:18:50, 339968 bytes
| Driver: KmRemove.exe, 9/16/2006 02:06:14, 45056 bytes
| Driver: Files.cab, 11/7/2006 17:52:00, 1877 bytes
| Driver: Help.cab, 11/7/2006 18:07:40, 705 bytes
+ HID Keyboard Device
| Vendor/Product ID: 0x0A5C, 0x4502
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 11/2/2006 09:51:12, 15872 bytes
| Driver: kbdclass.sys, 11/2/2006 10:49:57, 32872 bytes
| Vendor/Product ID: 0x0000, 0x0B30
| Service: kbdhid
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: i8042prt.sys, 11/2/2006 09:51:13, 54784 bytes
+ Alps Pointing-device
| Matching Device ID: *pnp0f13
| Upper Filters: ApfiltrService
| Service: i8042prt
| Driver: Apfiltr.sys, 10/30/2006 16:35:20, 140800 bytes
| Driver: Vxdif.dll, 10/18/2006 21:30:32, 100354 bytes
| Driver: Apoint.exe, 11/7/2006 21:57:58, 159744 bytes
| Driver: Ezcapt.exe, 9/24/2006 18:30:08, 167936 bytes
| Driver: Logo.bmp, 8/27/1997 11:23:30, 2694 bytes
| Driver: Gesture.bmp, 1/23/2003 23:29:56, 15122 bytes
| Driver: ApntEx.exe, 9/8/2006 16:06:08, 40960 bytes
| Driver: Apoint.dll, 11/2/2006 23:07:22, 806912 bytes
| Driver: EzLaunch.dll, 9/26/2006 18:48:00, 208896 bytes
| Driver: Elprop.dll, 4/27/2006 11:24:12, 102400 bytes
| Driver: EzAuto.dll, 8/7/2006 18:47:20, 69632 bytes
| Driver: ApointSP.chm, 9/1/2006 19:03:44, 33385 bytes
| Driver: ApointJP.chm, 8/28/2006 13:47:58, 29523 bytes
| Driver: ApointGR.chm, 9/1/2006 18:44:42, 34893 bytes
| Driver: ApointFR.chm, 9/1/2006 22:19:20, 34577 bytes
| Driver: ApointUS.chm, 8/28/2006 14:31:40, 29723 bytes
| Driver: ApointCT.chm, 9/1/2006 18:37:32, 31995 bytes
| Driver: ApointCS.chm, 9/1/2006 18:34:36, 32581 bytes
| Driver: ApointIT.chm, 9/1/2006 18:51:06, 33659 bytes
| Driver: ApointKR.chm, 9/1/2006 18:53:26, 33119 bytes
| Driver: ApInst.dll, 9/20/2006 00:55:20, 45056 bytes
| Driver: Uninstap.exe, 10/18/2006 13:55:32, 167936 bytes
| Driver: ApMsgFwd.exe, 9/8/2006 15:54:30, 42544 bytes
| Driver: WdfCoInstaller01001.dll, 4/20/2006 02:18:40, 1418720 bytes
| Driver: mouclass.sys, 11/2/2006 10:49:54, 31848 bytes
+ HID-compliant mouse
| Vendor/Product ID: 0x0A5C, 0x4503
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 11/2/2006 09:51:12, 15872 bytes
+ Dell HID-compliant Bluetooth Mouse
| Vendor/Product ID: 0x0000, 0x0B00
| Matching Device ID: hid\{00001124-0000-1000-8000-00805f9b34fb}_vid&0002046d_pid&b004&col01
| Upper Filters: LMouFilt
| Lower Filters: LHidFilt
| Service: mouhid
| Driver: LHidFilt.Sys, 10/11/2006 12:43:52, 25216 bytes
| Driver: LMouFilt.Sys, 10/11/2006 12:43:52, 25344 bytes
| Driver: KHALMNPR.Exe, 10/11/2006 12:32:34, 94208 bytes
| Driver: WdfCoInstaller01005.dll, 8/30/2006 04:47:16, 1447904 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 2/8/2007 00:50:31, 50792 bytes
| Driver: sermouse.sys, 11/2/2006 09:51:11, 19968 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 68.3 GB
Total Space: 102.1 GB
File System: NTFS
Model: Hitachi HTS541612J9SA00 ATA Device
Drive: D:
Free Space: 6.4 GB
Total Space: 10.2 GB
File System: NTFS
Drive: E:
Model: Optiarc DVD+-RW AD-5540A ATA Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.00.6000.16386 (English), 11/2/2006 09:51:44, 67072 bytes
System Devices
Name: Intel(R) PRO/Wireless 3945ABG Network Connection
Device ID: PCI\VEN_8086&DEV_4222&SUBSYS_10218086&REV_02\4&1EB84861&0&00E1
Driver: n/a
Name: Intel(R) 82801G (ICH7 Family) SMBus Controller - 27DA
Device ID: PCI\VEN_8086&DEV_27DA&SUBSYS_01CD1028&REV_01\3&2B8E0B4B&0&FB
Driver: n/a
Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_27D8&SUBSYS_01CD1028&REV_01\3&2B8E0B4B&0&D8
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.00.6000.16385 (English), 2/8/2007 00:50:28, 53760 bytes
Name: Intel(R) 82801G (ICH7 Family) PCI Express Root Port - 27D6
Device ID: PCI\VEN_8086&DEV_27D6&SUBSYS_01CD1028&REV_01\3&2B8E0B4B&0&E3
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.00.6000.16400 (English), 2/8/2007 00:50:31, 140392 bytes
Name: Intel(R) 82801G (ICH7 Family) PCI Express Root Port - 27D2
Device ID: PCI\VEN_8086&DEV_27D2&SUBSYS_01CD1028&REV_01\3&2B8E0B4B&0&E1
Name: Intel(R) 82801G (ICH7 Family) PCI Express Root Port - 27D0
Device ID: PCI\VEN_8086&DEV_27D0&SUBSYS_01CD1028&REV_01\3&2B8E0B4B&0&E0
Name: Intel(R) 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC
Device ID: PCI\VEN_8086&DEV_27CC&SUBSYS_01CD1028&REV_01\3&2B8E0B4B&0&EF
Driver: C:\Windows\system32\drivers\usbehci.sys, 6.00.6000.16391 (English), 2/8/2007 00:50:35, 38400 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.00.6000.16391 (English), 2/8/2007 00:50:35, 223744 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.00.6000.16391 (English), 2/8/2007 00:50:35, 191488 bytes
Driver: C:\Windows\system32\hccoin.dll, 6.00.6000.16391 (English), 2/8/2007 00:50:35, 8704 bytes
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CB
Device ID: PCI\VEN_8086&DEV_27CB&SUBSYS_01CD1028&REV_01\3&2B8E0B4B&0&EB
Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.00.6000.16391 (English), 2/8/2007 00:50:35, 22528 bytes
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CA
Device ID: PCI\VEN_8086&DEV_27CA&SUBSYS_01CD1028&REV_01\3&2B8E0B4B&0&EA
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9
Device ID: PCI\VEN_8086&DEV_27C9&SUBSYS_01CD1028&REV_01\3&2B8E0B4B&0&E9
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8
Device ID: PCI\VEN_8086&DEV_27C8&SUBSYS_01CD1028&REV_01\3&2B8E0B4B&0&E8
Name: Intel(R) 82801GBM/GHM (ICH7-M Family) Serial ATA Storage Controller - 27C4
Device ID: PCI\VEN_8086&DEV_27C4&SUBSYS_01CD1028&REV_01\3&2B8E0B4B&0&FA
Driver: C:\Windows\system32\DRIVERS\intelide.sys, 6.00.6000.16391 (English), 2/8/2007 00:50:59, 14952 bytes
Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.00.6000.16391 (English), 2/8/2007 00:50:59, 42600 bytes
Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.00.6000.16391 (English), 2/8/2007 00:50:59, 19048 bytes
Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.00.6000.16391 (English), 2/8/2007 00:50:59, 107112 bytes
Name: Intel(R) 82801GBM (ICH7-M/U) LPC Interface Controller - 27B9
Device ID: PCI\VEN_8086&DEV_27B9&SUBSYS_01CD1028&REV_01\3&2B8E0B4B&0&F8
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.00.6000.16400 (English), 2/8/2007 00:50:31, 13928 bytes
Name: Mobile Intel(R) 945GM/GU/PM/GMS/940GML/943GML and Intel(R) 945GT Express PCI Express Root Port - 27A1
Device ID: PCI\VEN_8086&DEV_27A1&SUBSYS_01CD1028&REV_03\3&2B8E0B4B&0&08
Name: Mobile Intel(R) 945GM/GU/PM/GMS/940GML/943GML and Intel(R) 945GT Express Processor to DRAM Controller - 27A0
Device ID: PCI\VEN_8086&DEV_27A0&SUBSYS_01CD1028&REV_03\3&2B8E0B4B&0&00
Driver: n/a
Name: Intel(R) 82801 PCI Bridge - 2448
Device ID: PCI\VEN_8086&DEV_2448&SUBSYS_01CD1028&REV_E1\3&2B8E0B4B&0&F0
Name: Broadcom 440x 10/100 Integrated Controller
Device ID: PCI\VEN_14E4&DEV_170C&SUBSYS_01CD1028&REV_02\4&16214B8C&0&00F0
Driver: n/a
Name: Ricoh xD-Picture Card Controller
Device ID: PCI\VEN_1180&DEV_0852&SUBSYS_01CD1028&REV_05\4&16214B8C&0&0CF0
Driver: C:\Windows\system32\DRIVERS\rixdptsk.sys, 6.00.0001.0000 (Japanese), 11/20/2006 20:13:58, 37376 bytes
Driver: C:\Windows\system32\rixdicon.dll, 11/20/2006 20:13:58, 16480 bytes
Name: Ricoh MMC Host Controller
Device ID: PCI\VEN_1180&DEV_0843&SUBSYS_01CD1028&REV_01\4&16214B8C&0&0AF0
Driver: C:\Windows\system32\DRIVERS\rimmptsk.sys, 6.00.0001.0000 (Japanese), 11/20/2006 20:13:56, 32256 bytes
Name: RICOH OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_1180&DEV_0832&SUBSYS_01CD1028&REV_00\4&16214B8C&0&08F0
Driver: C:\Windows\system32\DRIVERS\ohci1394.sys, 6.00.6000.16386 (English), 11/2/2006 09:55:16, 62080 bytes
Driver: C:\Windows\system32\DRIVERS\1394bus.sys, 6.00.6000.16386 (English), 11/2/2006 09:55:12, 53376 bytes
Name: SDA Standard Compliant SD Host Controller
Device ID: PCI\VEN_1180&DEV_0822&SUBSYS_01CD1028&REV_19\4&16214B8C&0&09F0
Driver: C:\Windows\system32\DRIVERS\sdbus.sys, 6.00.6000.16386 (English), 11/2/2006 09:35:12, 82432 bytes
Name: Ricoh Memory Stick Controller
Device ID: PCI\VEN_1180&DEV_0592&SUBSYS_01CD1028&REV_0A\4&16214B8C&0&0BF0
Driver: C:\Windows\system32\snymsico.dll, 1.00.0000.9120 (English), 11/20/2006 20:13:58, 90112 bytes
Driver: C:\Windows\system32\DRIVERS\rimsptsk.sys, 6.00.0001.0000 (Japanese), 11/20/2006 20:13:58, 43520 bytes
Name: NVIDIA GeForce Go 7900 GS
Device ID: PCI\VEN_10DE&DEV_0298&SUBSYS_019B1028&REV_A1\4&5D53E6A&0&0008
Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 7.15.0010.9746 (English), 12/14/2006 00:16:40, 4456416 bytes
Driver: C:\Windows\system32\nvd3dum.dll, 7.15.0010.9746 (English), 12/14/2006 00:16:38, 3055616 bytes
Driver: C:\Windows\system32\nvapi.dll, 7.15.0010.9746 (English), 12/14/2006 00:16:36, 303104 bytes
Driver: C:\Windows\system32\nvoglv32.dll, 7.15.0010.9746 (English), 12/14/2006 00:16:44, 5685248 bytes
Driver: C:\Windows\system32\nvcpl.dll, 7.15.0010.9746 (English), 12/14/2006 00:16:38, 7766016 bytes
Driver: C:\Windows\system32\nvsvc.dll, 7.15.0010.9746 (English), 12/14/2006 00:16:44, 90191 bytes
Driver: C:\Windows\system32\nvmctray.dll, 7.15.0010.9746 (English), 12/14/2006 00:16:42, 81920 bytes
Driver: C:\Windows\system32\nvdisps.dll, 7.15.0010.9746 (English), 12/14/2006 00:16:38, 5619712 bytes
Driver: C:\Windows\system32\nvdispsr.dll, 7.15.0010.9746 (English), 12/14/2006 00:16:38, 5230592 bytes
Driver: C:\Windows\system32\nvgames.dll, 7.15.0010.9746 (English), 12/14/2006 00:16:40, 3063808 bytes
Driver: C:\Windows\system32\nvgamesr.dll, 7.15.0010.9746 (English), 12/14/2006 00:16:40, 3207168 bytes
Driver: C:\Windows\system32\nvmccss.dll, 7.15.0010.9746 (English), 12/14/2006 00:16:42, 188416 bytes
Driver: C:\Windows\system32\nvmccssr.dll, 7.15.0010.9746 (English), 12/14/2006 00:16:42, 458752 bytes
Driver: C:\Windows\system32\nvmobls.dll, 7.15.0010.9746 (English), 12/14/2006 00:16:42, 888832 bytes
Driver: C:\Windows\system32\nvmoblsr.dll, 7.15.0010.9746 (English), 12/14/2006 00:16:42, 2854912 bytes
Driver: C:\Windows\system32\nvvitvs.dll, 7.15.0010.9746 (English), 12/14/2006 00:16:44, 3321856 bytes
Driver: C:\Windows\system32\nvvitvsr.dll, 7.15.0010.9746 (English), 12/14/2006 00:16:44, 3338240 bytes
Driver: C:\Windows\system32\nvmccs.dll, 7.15.0010.9746 (English), 12/14/2006 00:16:42, 229376 bytes
Driver: C:\Windows\system32\nvmccsrs.dll, 7.15.0010.9746 (English), 12/14/2006 00:16:42, 45056 bytes
Driver: C:\Windows\system32\nvcpluir.dll, 1.03.0007.0037 (English), 12/14/2006 00:16:38, 1019904 bytes
Driver: C:\Windows\system32\nvexpbar.dll, 1.03.0007.0037 (English), 12/14/2006 00:16:40, 307200 bytes
Driver: C:\Windows\system32\nvwss.dll, 7.15.0010.9746 (English), 12/14/2006 00:16:46, 2048000 bytes
Driver: C:\Windows\system32\nvwssr.dll, 7.15.0010.9746 (English), 12/14/2006 00:16:46, 2371584 bytes
Driver: C:\Windows\system32\nvcpl.cpl, 1.03.0007.0037 (English), 12/14/2006 00:16:38, 69632 bytes
Driver: C:\Windows\system32\nvcolor.exe, 7.15.0010.9746 (English), 12/14/2006 00:16:36, 147456 bytes
Driver: C:\Windows\system32\nvcplui.exe, 1.03.0007.0037 (English), 12/14/2006 00:16:38, 806912 bytes
Driver: C:\Windows\system32\nvudisp.exe, 1.00.0001.0056 (English), 12/14/2006 00:16:44, 356352 bytes
Driver: C:\Windows\system32\nvapps.xml, 12/14/2006 00:16:36, 87160 bytes
Driver: C:\Windows\system32\nvwsapps.xml, 12/14/2006 00:16:46, 70770 bytes
Driver: C:\Windows\help\nvcpl\nvcpl.chm, 12/14/2006 00:16:36, 104248 bytes
Driver: C:\Windows\help\nvcpl\nvdsp.chm, 12/14/2006 00:16:40, 182371 bytes
Driver: C:\Windows\help\nvcpl\nv3d.chm, 12/14/2006 00:16:36, 99664 bytes
Driver: C:\Windows\help\nvcpl\nvmob.chm, 12/14/2006 00:16:42, 54878 bytes
Driver: C:\Windows\help\nvcpl\nvwks.chm, 12/14/2006 00:16:44, 171946 bytes
Driver: C:\Windows\system32\nvuninst.exe, 1.00.0001.0056 (English), 12/14/2006 00:16:44, 356352 bytes
Driver: C:\Windows\system32\nvdisp.nvu, 12/14/2006 00:16:38, 3181 bytes
Driver: C:\Windows\system32\dpinst.exe, 2.00.0001.0000 (English), 12/14/2006 00:16:34, 521128 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
MP3 Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00600800,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Sonic AVC Decoder DMO,0x00340031,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
Annodex Mux Filter,0x00200000,1,0,dsfAnxMux.dll,
CMML Decode Filter,0x00800002,1,1,dsfCMMLDecoder.dll,
CMML Raw Source Filter,0x00600000,0,0,dsfCMMLRawSource.dll,
FLAC Decode Filter,0x00600000,1,1,dsfFLACDecoder.dll,
FLAC Encode Filter,0x00200000,1,1,dsfFLACEncoder.dll,
Native FLAC Source Filter,0x00600000,0,0,dsfNativeFLACSource.dll,
Ogg Demux Packet Source Filter,0x00600000,0,0,dsfOggDemux2.dll,
Ogg Mux Filter,0x00200000,1,0,dsfOggMux.dll,
OGM Decode Filter,0x00600000,1,1,dsfOGMDecoder.dll,
Speex Decode Filter,0x00600000,1,1,dsfSpeexDecoder.dll,
Speex Encode Filter,0x00200000,1,1,dsfSpeexEncoder.dll,
Subtitle VMR9 Filter,0x00800002,1,1,dsfSubtitleVMR9.dll,
Theora Decode Filter,0x00600000,1,1,dsfTheoraDecoder.dll,
Theora Encode Filter,0x00200000,1,1,dsfTheoraEncoder.dll,
Vorbis Decode Filter,0x00600000,1,1,dsfVorbisDecoder.dll,
Vorbis Encode Filter,0x00200000,1,1,dsfVorbisEncoder.dll,
Roxio Vob Loader,0x00200000,0,1,VOBLoader.ax,9.00.0001.0078
ROXIO VCFLatency 3.0,0x00200000,1,1,latency.ax,9.00.0001.0074
Full Screen Renderer,0x00200000,1,0,,6.06.6000.16386
ROXIO VCFWaveform 1.0,0x00200000,1,0,waveform.ax,9.00.0001.0074
ROXIO SceneRecorder 1.0,0x00200000,1,0,SceneRecorderFilt.ax,9.00.0001.0074
ROXIO Image/Colour Source 3.0,0x00200000,0,1,ImageSource.ax,9.00.0001.0074
Multiple File Output,0x00200000,2,2,WMM2FILT.dll,
roxio DCFilters Dragon Lair,0x00200000,0,1,DCFilters9.dll,9.00.0001.0008
MainConcept (Sonic) DV Video Decoder,0x00600000,1,1,sonicmcdsdv.ax,2.01.0000.0004
MainConcept (Sonic) DV Video Encoder,0x00200000,1,1,sonicmcdsdv.ax,2.01.0000.0004
WMT Black Frame Generator,0x00200000,1,1,WMM2FILT.dll,
WMT Import Filter,0x00200000,0,1,WMM2FILT.dll,
roxio DCFilters Subpicture Mixer,0x00200000,2,1,DCFilters9.dll,9.00.0001.0008
Sonic Solutions AMR Decoder,0x00800003,1,1,sonicamrd.ax,0.00.0007.60426
DV Muxer,0x00400000,0,0,,6.06.6000.16386
ROXIO AudioGrabber 3.0,0x00200000,1,0,thumbnailgraber.ax,9.00.0001.0074
roxio DCFilters Mpeg I/II Decoder,0x00200000,1,1,DCFilters9.dll,9.00.0001.0008
ROXIO VideoCombine 3.0,0x00200000,1,0,VideoCombine.ax,9.00.0001.0074
Roxio Smart Decoder,0x00200000,1,1,MPEG2VidCodec.dll,9.00.0002.0008
Roxio Transport Stream Source,0x00200000,0,1,TSMPEGSource.dll,9.00.0002.0008
Color Space Converter,0x00400001,1,1,,6.06.6000.16386
WMT Interlacer,0x00200000,1,1,WMM2FILT.dll,
WM ASF Reader,0x00400000,0,0,,11.00.6000.6324
ROXIO AudioConvert 3.0,0x00200000,1,1,audconv.ax,9.00.0001.0074
ROXIO WAV Dest 3.0,0x00200000,0,0,WavHead.ax,9.00.0001.0074
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.6000.6324
Roxio Audio Stream Reader Filter,0x00200000,1,0,RxDSAudioStreamWriter.ax,1.00.0000.0001
AVI Splitter,0x00600000,1,1,,6.06.6000.16386
Roxio Repacketizer Filter,0x00200000,1,1,RepackFilter.dll,9.00.0002.0008
VGA 16 Color Ditherer,0x00400000,1,1,,6.06.6000.16386
ROXIO SubPicture Encoder,0x00200000,1,1,SubPictEnc.dll,9.00.0002.0008
Microsoft MPEG-2 Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,11.00.5840.6324
ROXIO Audio VCFLooper 3.0,0x00200000,1,1,Looper.ax,9.00.0001.0074
Roxio MPEG2 Video Decoder,0x00200000,1,1,MPEG2VidCodec.dll,9.00.0002.0008
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.6000.16386
ROXIO VCFpeakmeter 3.0,0x00200000,1,1,peakmeter.ax,9.00.0001.0074
Roxio MPEG1 Encoder,0x00200000,1,1,MPEG1VidCodec.dll,9.00.0002.0008
WMT Format Conversion,0x00200000,1,1,WMM2FILT.dll,
9x8Resize,0x00200000,1,1,WMM2FILT.dll,
ROXIO DVDCrossGraphEx Source 3.0,0x00200000,0,1,DVDCrossGraphEx.ax,9.00.0001.0074
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.6000.16386
WMT Virtual Source,0x00200000,0,1,WMM2FILT.dll,
Microsoft TV Caption Decoder,0x00200001,1,0,MSTVCapn.dll,6.00.6000.16386
MJPEG Decompressor,0x00600000,1,1,,6.06.6000.16386
ROXIO VCFDVSceneDetect 1.0,0x00200000,1,2,DVSceneDetectFilt.ax,9.00.0001.0074
Roxio VOB Formatter,0x00200000,1,1,VOBFormatter.ax,9.00.0001.0078
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.00.6000.16386
MPEG-I Stream Splitter,0x00600000,1,2,,6.06.6000.16386
SAMI (CC) Parser,0x00400000,1,1,,6.06.6000.16386
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.6000.16386
ROXIO ColorSpace Converter 3.0,0x00200000,1,1,ColorSpConv.dll,9.00.0001.0074
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.6000.16386
WMT AudioAnalyzer,0x00200000,1,1,WMM2FILT.dll,
Sonic MPEG-4 Video Decoder,0x00200000,1,1,sonicm4vd.ax,1.00.0016.51201
ROXIO Audio Source 3.0,0x00200000,0,1,AudioSrc.ax,9.00.0001.0074
ROXIO DVDCrossGraphEx Renderer 3.0,0x00200000,1,0,DVDCrossGraphEx.ax,9.00.0001.0074
Microsoft MPEG-2 Video Encoder,0x00200000,2,0,msmpeg2enc.dll,11.00.6000.6324
ROXIO Pin Tee,0x00200000,1,1,RoxioInfTee.ax,
ROXIO QuickGrabber 3.0,0x00200000,1,0,thumbnailgraber.ax,9.00.0001.0074
Stretch Video,0x00200000,1,1,WMM2FILT.dll,
CyberLink MPEG-1 Splitter,0x00805000,1,2,CLM1Splter.ax,2.02.0000.3710
CyberLink Audio Decoder (MD3),0x00601000,1,1,CLAud.ax,6.00.0000.2806
CyberLink AudioCD Filter (MD3),0x00600000,0,1,CLAudioCD.AX,5.00.0000.3620
Roxio Audio Source Filter,0x00400000,0,1,RxDSAudioSource.ax,9.00.0000.0000
CyberLink Video Effect (MD3),0x00200000,1,1,CLVidFx.ax,1.00.0000.1523
CyberLink Video/SP Decoder (MD3),0x00600000,2,3,CLVSD.ax,6.00.0000.3222
CyberLink Line21 Decoder Filter (MD3),0x00200000,0,2,CLLine21.ax,4.00.0000.6317
CyberLink Audio Effect (MD3),0x00200000,1,1,claudfx.ax,6.00.0000.2524
Cyberlink SubTitle Importor (MD3),0x00200000,1,1,CLSubTitle.ax,1.00.0000.1604
CyberLink TimeStretch Filter (MD3),0x00200000,1,1,clauts.ax,1.00.0000.3711
CyberLink DVD Navigator (MD3),0x00600000,0,3,CLNavX.ax,6.00.0000.1925
CyberLink Demultiplexer (MD3),0x00200000,1,0,CLDemuxer.ax,1.00.0000.3726
CyberLink MPEG-2 Splitter,0x00805000,1,2,CLM2Splter.ax,2.02.0000.3710
Internal Script Command Renderer,0x00800001,1,0,,6.06.6000.16386
CyberLink MP3 Wrapper-PCM,0x00600000,1,1,CLMP3Wrap.ax,1.00.0000.0000
Roxio MPEG Stream Analyzer,0x00200000,1,2,MPEGStreamAnalyzer.dll,9.00.0002.0008
Sonic MPEG-2 Video Decoder,0x00200000,2,2,sonicm2vd.ax,1.00.0197.60322
MPEG Audio Decoder,0x03680001,1,1,,6.06.6000.16386
ROXIO CrossGraphEx Source 3.0,0x00200000,0,1,CrossGraphEx.ax,9.00.0001.0074
Roxio MPEG2 Encoder,0x00200000,1,1,MPEG2VidCodec.dll,9.00.0002.0008
ROXIO VCFDvrSupport 3.0,0x00200000,1,1,DvrSupportFilt.ax,9.00.0001.0074
DV Splitter,0x00600000,1,2,,6.06.6000.16386
CoreImgSrc,0x00200000,0,0,CoreImgSrc.ax,1.02.0000.0000
Video Mixing Renderer 9,0x00200000,1,0,,6.06.6000.16386
ROXIO LPCMSyncFilter,0x00200000,1,1,LPCMSyncFilter.dll,9.00.0002.0008
ROXIO Audio VCFChunker 3.0,0x00200000,1,1,Chunker.ax,9.00.0001.0074
ROXIO Pan Zoom 3.0,0x00200000,1,1,PanZoom.ax,9.00.0001.0074
VCG Null Renderer 3.0,0x00200000,1,0,VideoCompositing.ax,
Roxio Audio Stream Reader Filter,0x00200000,1,0,RxDSAudioStreamReader.ax,9.00.0000.0000
Roxio Smart Encoder,0x00200000,2,1,MPEG2VidCodec.dll,9.00.0002.0008
Roxio Plasma CrossGraph Source,0x00200000,0,1,PlasmaCGFilter.ax,9.00.0001.0078
ROXIO InputSelector 3.0,0x00200000,1,0,InputSelector.ax,9.00.0001.0074
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,11.00.6000.6324
Frame Eater,0x00200000,1,1,WMM2FILT.dll,
CoreMovSrc,0x00200000,0,0,CoreMovSrc.ax,1.02.0000.0000
Allocator Fix,0x00200000,1,1,WMM2FILT.dll,
ROXIO ThumbnailGrabber 3.0,0x00200000,1,0,thumbnailgraber.ax,9.00.0001.0074
ACM Wrapper,0x00600000,1,1,,6.06.6000.16386
ROXIO VCFVideoCutList 3.0,0x00200000,1,1,vCutList.ax,9.00.0001.0074
Video Renderer,0x00800001,1,0,,6.06.6000.16386
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.6000.16386
Capture ASF Writer,0x00200000,0,0,WMM2FILT.dll,
Line 21 Decoder,0x00600000,1,1,,6.06.6000.16386
Video Port Manager,0x00600000,2,1,,6.06.6000.16386
Video Renderer,0x00400000,1,0,,6.06.6000.16386
ROXIO Deinterlace 3.0,0x00200000,1,1,DeInter.ax,9.00.0001.0074
Bitmap Generate,0x00200000,1,1,WMM2FILT.dll,
Proxy Sink,0x00200000,1,0,WMM2FILT.dll,
Sonic MPEG Audio Decoder,0x00200000,1,1,sonicdsmpeg.ax,1.01.3858.0000
Sonic MPEG Video Decoder,0x00200000,1,1,sonicdsmpeg.ax,1.01.3858.0000
Proxy Source,0x00200000,0,1,WMM2FILT.dll,
ROXIO ListImage Source 3.0,0x00200000,0,1,ListImageSource.ax,9.00.0001.0074
WM ASF Writer,0x00400000,0,0,,11.00.6000.6324
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.00.6000.16386
ROXIO Video VCFLooper 3.0,0x00200000,1,1,vlooper.ax,9.00.0001.0074
WMT Sample Information Filter,0x00200000,1,1,WMM2FILT.dll,
File writer,0x00200000,1,0,,6.06.6000.16386
Roxio Plasma CrossGraph Renderer,0x00200000,1,0,PlasmaCGFilter.ax,9.00.0001.0078
VMR9 Wrapper 3.0,0x00200000,1,0,VideoCompositing.ax,
ROXIO SpyPos 3.0,0x00200000,1,1,MGINullIP.ax,9.00.0001.0074
roxio DCFilters Smart Resizer,0x00200000,1,1,DCFilters9.dll,9.00.0001.0008
ROXIO QT Source,0x00200000,0,1,QTSource.ax,9.00.0001.0074
ROXIO Sewer 3.0,0x00200000,1,0,MVWcDSutil.dll,9.00.0001.0074
Roxio MPEG1 Muxer,0x00200000,2,1,MPEG1Muxer.dll,9.00.0002.0008
ROXIO VCFAudioMixer 3.0,0x00200000,1,1,audmf.ax,9.00.0001.0074
ROXIO CrossGraphEx Renderer 3.0,0x00200000,1,0,CrossGraphEx.ax,9.00.0001.0074
CoreNullXfrm Filter,0x00200000,1,1,CoreNullXfrm.ax,1.02.0000.0000
DVD Navigator,0x00200000,0,3,,6.06.6000.16386
WMT DV Extract,0x00200000,1,1,WMM2FILT.dll,
ROXIO InputSelectorNew 3.0,0x00200000,1,0,InputSelector.ax,9.00.0001.0074
Overlay Mixer2,0x00200000,1,1,,6.06.6000.16386
Sonic MP4 Demultiplexer,0x00800101,1,2,sonicMP4Demux.ax,1.04.0402.60802
AVI Draw,0x00600064,9,1,,6.06.6000.16386
Microsoft MPEG-2 Audio Encoder,0x00200000,2,0,msmpeg2enc.dll,11.00.6000.6324
WST Pager,0x00800000,1,1,WSTPager.ax,6.06.6000.16386
ROXIO LVM File Source (Async.),0x00200000,0,1,LVMAsync.ax,9.00.0001.0078
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.6000.16386
Record Queue,0x00200000,1,1,WMM2FILT.dll,
DV Video Decoder,0x00800000,1,1,,6.06.6000.16386
LVMWriter,0x00200000,1,0,LVMWriter.ax,9.00.0001.0078
VCG Video Mixer 3.0,0x00200000,0,1,VideoCompositing.ax,
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.6000.16386
Null Renderer,0x00200000,1,0,qedit.dll,6.06.6000.16386
WMT Log Filter,0x00200000,1,1,WMM2FILT.dll,
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.6000.16386
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,11.00.6000.6324
CoreCaption Filter,0x00200000,1,1,CoreCaption.ax,1.02.0000.0000
Roxio MPEG Analyzer,0x00200000,1,0,RoxioMPEGProp.dll,9.00.0002.0008
WMT Virtual Renderer,0x00200000,1,0,WMM2FILT.dll,
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.6000.16386
roxio DCFilters DVD Reader,0x00200000,0,1,DCFilters9.dll,9.00.0001.0008
Smart Tee,0x00200000,1,2,,6.06.6000.16386
ROXIO MPEG Writer,0x00200000,1,0,MGIRawWriter.dll,9.00.0002.0008
Roxio MPEG2 Muxer,0x00200000,4,0,MPEG2Muxer.dll,9.00.0002.0008
VCGImageSource,0x00200000,0,1,VideoCompositing.ax,
Overlay Mixer,0x00200000,0,0,,6.06.6000.16386
RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,6.00.0012.1442
AVI Decompressor,0x00600000,1,1,,6.06.6000.16386
roxio DCFilters DVD Splitter,0x00200000,1,3,DCFilters9.dll,9.00.0001.0008
WMT MuxDeMux Filter,0x00200000,0,0,WMM2FILT.dll,
NetBridge,0x00200000,2,0,netbridge.dll,6.01.6000.16386
AVI/WAV File Source,0x00400000,0,2,,6.06.6000.16386
WMT Volume,0x00200000,1,1,WMM2FILT.dll,
Wave Parser,0x00400000,1,1,,6.06.6000.16386
MIDI Parser,0x00400000,1,1,,6.06.6000.16386
Multi-file Parser,0x00400000,1,1,,6.06.6000.16386
File stream renderer,0x00400000,1,1,,6.06.6000.16386
PSI Parser,0x00200000,0,0,PsiParser.ax,
roxio DCFilters Audio Sync Filter 2,0x00200000,1,1,DCFilters9.dll,9.00.0001.0008
CoreVolume Filter,0x00200000,1,1,CoreVolume.ax,1.02.0000.0000
WMT VIH2 Fix,0x00200000,1,1,WMM2FILT.dll,
Media Analyser,0x00200000,1,2,mediaanalyser.ax,9.00.0001.0074
CyberLink Video/SP Decoder (ShEX),0x005ffc18,2,3,CLImageVSD.ax,6.00.0000.1625
Microsoft MPEG-1/DD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,11.00.5840.6324
AVI Mux,0x00200000,1,0,,6.06.6000.16386
Line 21 Decoder 2,0x00600002,1,1,,6.06.6000.16386
File Source (Async.),0x00400000,0,1,,6.06.6000.16386
File Source (URL),0x00400000,0,1,,6.06.6000.16386
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.6000.16386
Roxio MPEG1 Audio Encoder,0x00200000,1,1,RoxioAudioEnc.dll,9.00.0002.0008
roxio DCFilters DVD Muxer,0x00200000,1,1,DCFilters9.dll,9.00.0001.0008
AudioRecorder WAV Dest,0x00200000,0,0,,6.00.6000.16386
AudioRecorder Wave Form,0x00200000,0,0,,6.00.6000.16386
SoundRecorder Null Renderer,0x00200000,0,0,,6.00.6000.16386
ROXIO Scene Detector 3.0,0x00200000,1,1,SceneDetector.ax,9.00.0001.0074
ROXIO Simple Dump 3.0,0x00200000,1,0,RxSimpleDump.ax,9.00.0001.0074
Infinite Pin Tee Filter,0x00200000,1,1,,6.06.6000.16386
WMT Switch Filter,0x00200000,1,1,WMM2FILT.dll,
Roxio Audio Decoder (DVD),0x00200000,1,1,RoxioDVDAudio.dll,9.00.0002.0008
ROXIO Video Resampler 3.0,0x00200000,1,1,VResamFilt.ax,9.00.0001.0074
Enhanced Video Renderer,0x00200000,1,0,evr.dll,5.00.0001.0001
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,WMM2FILT.dll,
Roxio MPEG2 Demuxer,0x00600000,1,2,RoxioMPEGDemuxer.dll,9.00.0002.0008
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.6000.16386
MPEG Video Decoder,0x40000001,1,1,,6.06.6000.16386
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,6.00.6000.16386
WDM Streaming Data Transforms:
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,6.00.6000.16386
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,,6.06.6000.16386
MJPEG Compressor,0x00200000,0,0,,6.06.6000.16386
Cinepak Codec by Radius,0x00200000,1,1,,6.06.6000.16386
Intel IYUV codec,0x00200000,1,1,,6.06.6000.16386
Microsoft RLE,0x00200000,1,1,,6.06.6000.16386
Microsoft Video 1,0x00200000,1,1,,6.06.6000.16386
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IMA ADPCM,0x00200000,1,1,,6.06.6000.16386
Microsoft ADPCM,0x00200000,1,1,,6.06.6000.16386
ACELP.net,0x00200000,1,1,,6.06.6000.16386
Windows Media Audio V1,0x00200000,1,1,,6.06.6000.16386
Windows Media Audio V2,0x00200000,1,1,,6.06.6000.16386
GSM 6.10,0x00200000,1,1,,6.06.6000.16386
CCITT A-Law,0x00200000,1,1,,6.06.6000.16386
CCITT u-Law,0x00200000,1,1,,6.06.6000.16386
MPEG Layer-3,0x00200000,1,1,,6.06.6000.16386
Audio Capture Sources:
Microphone / Line In (SigmaTel ,0x00200000,0,0,,6.06.6000.16386
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,,6.06.6000.16386
Microsoft GS Wavetable Synth,0x00200000,1,0,,6.06.6000.16386
WDM Streaming Capture Devices:
,0x00000000,0,0,,
MuxedIn,0x00200000,1,1,,6.00.6000.16386
,0x00000000,0,0,,
WDM Streaming Rendering Devices:
LineOut,0x00200000,1,1,,6.00.6000.16386
,0x00000000,0,0,,
SpdifOut,0x00200000,1,1,,6.00.6000.16386
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6000.16386
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6000.16386
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6000.16386
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6000.16386
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.6000.16386
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.6000.16386
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.6000.16386
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,EncDec.dll,6.06.6000.16386
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.6000.16386
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.6000.16386
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (SigmaTel High Definit,0x00200000,1,0,,6.06.6000.16386
CyberLink Audio Renderer (MD3),0x00200000,1,0,CLADR.ax,6.00.0000.2812
Default DirectSound Device,0x00800000,1,0,,6.06.6000.16386
Default WaveOut Device,0x00200000,1,0,,6.06.6000.16386
Digital Output Device (SPDIF) (,0x00200000,1,0,,6.06.6000.16386
DirectSound: Digital Output Device (SPDIF) (SigmaTel High Definition Audio CODEC),0x00200000,1,0,,6.06.6000.16386
DirectSound: Speakers (SigmaTel High Definition Audio CODEC),0x00200000,1,0,,6.06.6000.16386
Reply 51 of 62, by laracroft.net
Well... it does seem to (as does the Product ID). Hereto attached the three snapshots, one for each successive boot.
If you have a minute to spare someday, can you please briefly explain what NIC is? Again, just out of curiosity...
(I'm tempted to thank you for your help with each post, but I'm afraid it might get boring...)
Reply 52 of 62, by laracroft.net
Well, 2007Jenn, that's pretty impressive; I liked the smiley hidden in the code towards the bottom particularly.
I didn't know you could do that. I'll bookmark the tombraiderforums, it looks like there are quite a few interesting things over there...
Good night to all!
Reply 53 of 62, by 2007Jenn
Sorry - I didn't mean to flood the Forums with randomness about my PC!
Yep, the TR Forums are great for help with TR2 and above (BTW - I got TR2 and 4 up an running fine on Vista - the rest I'm not a big fan of so didn't try).
TR1 is *always* the problem, but it is the best IMO.
Reply 54 of 62, by Glidos
Eek! So the NIC3 is changing every reboot. It's the unique identifier for your network card. Really all three lines should be identical. They are supposed to be the same information obtained in three different ways. Interesting that method 1 is working consistantly.
Reply 55 of 62, by laracroft.net
Oh-oh. You make that sound pretty bad.
2007Jenn, I have a confession to make: I can't figure out what some of the abbreviations you use mean. Care to enlighten me, please? :-)
Actually, I really enjoyed Legend, and I'm looking forward to Anniversary, but I really like them all in their own way (though I have to admit AOD was botched).
Reply 56 of 62, by DosFreak
AFAIK=As Far as I Know
OP=Original Poster (The topic starter)
IMO=In My Opinion
RTFM=Read The Fine Manual
STFU=Shut the Fine Up
OMGWTFBBQ=Oh My God Whiskey Tango Foxtrot BBQ (Acronym used when something is really messed up)
WTF=What The Fine.
Ex: Creative announced today that you will have to pay for their Creative Alchemy wrapper for DirectSound3D->OPENAL.
Response: OMGWTFBBQ!!!! (Okay, not really in that situation. That one just deserves WTF).
Make your games work offline
Reply 57 of 62, by laracroft.net
Cheers. I'm going to copy that down somewhere for future reference.
I was just about to write that I'd just figured out what IMO was, having just seen it in a different context on another forum, when I saw your reply.
BTW, I like RTFM best. It's got me laughing out loud in the office (I'm not writing any of this, officially; actually, officially, I'm not logged in at all, and therefore I can't be logging out -now).
Reply 58 of 62, by Glidos
Here's a version of VDos32 that might manage to stay unlocked through a reboot in Vista.
Reply 59 of 62, by laracroft.net
Hi!
I've downloaded and installed VDos32 v0_5a, and it does seem to have fixed the problem (2 reboots and the program launched TR1 automatically both times).
Thanks!
