Dreams to Reality Glidos
First post, by rain
hi , using glidos for dreams to reality with 3dfx mode but got this error.
_retired retro pc user_
Reply 1 of 12, by Glidos
That looks like the DREAMSFX program is looking for games content on the disk and not finding it. How did you install Dreams to Reality?
I can't at the moment find my own installation or the CD, so I can't test here. Hopefully it will turn up.
Reply 2 of 12, by rain
Using dosbox-x to install.
Also using windows 8.1
Reply 3 of 12, by zirkoni
You're trying to run the exe-file from the root of the emulated C-drive. That's probably the issue.
When you installed the game it probably put the game in e.g. C:\DREAMS
So change your mount command and in DOSBox cd into the game directory.
https://youtube.com/@zirkoni42
Reply 4 of 12, by rain
zirkoni wrote on 2024-02-09, 13:13:
error..
Reply 5 of 12, by rain
how to change mount command ? did not get it 🙁
it says ILLEGAL COMMAND MOUNT
Reply 6 of 12, by Glidos
Are you typing these commands directly into a command prompt? The intended mechanism is to allow Glidos to start the game. You just need to:
  • Select "Dreams to Reality" from the "Glide Server" dialog
  • Click the "Adjust..." button to open the "Game details" dialog
  • Click the "Executable" tab
  • Click the "Browse" button to find and select the executable
  • Close the "Game details" dialog
  • Click the "Start game" button
Reply 7 of 12, by rain
Iam not typing these codes
i did exactly same thing and glidos gives error mentioned before
Reply 8 of 12, by Glidos
Where did you get your copy of the game? Maybe I can get the same version and experiment here.
Reply 10 of 12, by Glidos
Thanks. I'll take a look, see if I can get it working. Might take a while.
Reply 11 of 12, by rain
Glidos wrote on 2024-02-09, 16:33:
any news 😀
Reply 12 of 12, by Glidos
Not had a chance as yet. Could be a week or two.
