i need help!
First post, by average joe
well i d/led all the stuff from the site did everything it says it cant find the tomb raider cd in both of the programs i got this weird tomb raider cd tho i had like 3 of em 2 that was orignals and one weird one cant find the others this cd has abunch of demos and and old old aol vesion it even has a demo of final fantasy 7
Reply 1 of 7, by Snover
You have to put it in your first CD-ROM drive, otherwise it won't work. Also, make sure paths are correctly set in the Tomb Raider configuration files.
Yes, it’s my fault.
Reply 2 of 7, by average joe
the cd is in the cd rom and it still dont work for some reason im not sure how to set the path in the tomb raider config
Reply 3 of 7, by Snover
The first CD-ROM?
Yes, it’s my fault.
Reply 4 of 7, by average joe
ya the 1st one d: i tryed it in E: too like i said before this cd is a diffrent one from the orginal it has abunch of demos and the tomb raider files are in a folder called tomb
Reply 5 of 7, by average joe
and i think thats why it dont want to find the cd cus the orignal just had the files in d:/ i think
Reply 6 of 7, by Snover
*stare*
Did you try changing the path in the GliDOS.ini file to the proper location on the CD?
Yes, it’s my fault.
Reply 7 of 7, by Nicht Sehr Gut
Joe. Take this advice. Type using full sentences and avoid using pronouns for everything.
The Glidos.ini file inside your GLIDOS directory contains the location of your game's TOMB.EXE file so that GliDOS knows where the game is... If it is installed anywhere other than the default location (which is C:\Tombraid\Tomb.exe), then you must edit the Glidos.ini file to match the location of your TOMB.EXE file.
So, for example, if it's inside a directory called "TR" on your E: drive, then you must change
to
E:\TR\Tomb.exe
