Glidos won't start
First post, by Unregistered
I've installed the Tomb Raider files using the TR installer and installed Glidos 1.24 but when I click on the glidos icon I get the following error messages pop up:
"The GLIDOS.EXE file is
linked to missing export DINPUT.DLL DirectInputCreateEx."
"C:\Program Files\Glidos\Glidos.exe
A device attached to the the system is not functioning."
I've tried installing without sound but the result is the same.
Reply 1 of 3, by Glidos
This is mentioned in another thread, and someone found a solution. Try using the Vogons search facility with DINPUT as the search word.
Reply 3 of 3, by Glidos
I'm sure there was another thread...
Anyway, isn't this just a case of installing the latest DirectX from Microsoft?
