cannot install
Reply 20 of 22, by Glidos
Glidos wrote:
Can you not set up the sound card but not test it?
Let's try that again: can you not set up the sound card missing out the testing stage?
That's closer to a sentence that the first go. 😀
Reply 21 of 22, by Snover
Uh, dude. No, it's not. What the hell are you trying to say? Lay off the crack. Seriously. It's bad for you.
Yes, it’s my fault.
Reply 22 of 22, by Nigel
When I tried the new install last night I couldn't get *near* to the sound config, it had gone belly-up long before.
Does anyone know if we can manually edit HMISET.CFG ? Would it be a good idea to pre-config some different HIMSET.CFG files, listing the sound set-ups etc) and posting those?
Just a thought.
Sadly I think my WinXP is NTFS at mo. I'm not got to blight it by getting anything wrong! (If I can help it!).
Mind you, if an installer can be written to include Setup as well as running the game, then there's be no probs anyway.
