i need help!
First post, by average joe
well i d/led all the stuff from the site did everything it says it cant find the tomb raider cd in both of the programs i got this weird tomb raider cd tho i had like 3 of em 2 that was orignals and one weird one cant find the others this cd has abunch of demos and and old old aol vesion it even has a demo of final fantasy 7
Reply 7 of 7, by Nicht Sehr Gut
Joe. Take this advice. Type using full sentences and avoid using pronouns for everything.
The Glidos.ini file inside your GLIDOS directory contains the location of your game's TOMB.EXE file so that GliDOS knows where the game is... If it is installed anywhere other than the default location (which is C:\Tombraid\Tomb.exe), then you must edit the Glidos.ini file to match the location of your TOMB.EXE file.
So, for example, if it's inside a directory called "TR" on your E: drive, then you must change
to
E:\TR\Tomb.exe
