First post, by Unregistered
I have 'Glidos' working with 'Tombraider 1' on my
3dfx 5500AGP video card in WinXP with sound:
1) Install 'VDMsound' first.
2) Install 'Glidos' and select 'VDMsound'.
3) Install 'Tomb1' using the 'TRInst.exe' provided by
'Glidos' author, (XP won't display the setup screen).
4) Replace the 'Glide2x.dll' in the 'Glidos' directory with
the one from my 3dfx video drivers for WinXP.
5) Raplace the 'Tomb.exe' with the 'Voodoo Rush' version,
(this is on my 'Tomb' CD).
6) Start 'Glidos' and 'tomb' and when the '3dfx' logo appears
DO NOT press the 'ESC' key.
After the logo disappears the movie screen goes BLACK!
Wait for the audio from the movie to begin and THEN press
the 'ESC' key.
You will need to do this for every movie since there is a black
screen every time they try to play.
NOTE: I will try removing the VESA item from the ini file later
to see if that solves the movie display problem.
I hope this helps anyone trying to run TR1 on a 3dfx 5500
using 'Glidos'...
