First post, by Unregistered
hi,
i have the original tombraider 1 cd.
Like i read in other post, i download the trub3dfx.exe (german file) to have the new level of tomb raider 1.
i change the glidos.ini and erase the checkdisk line but problem:
- first if you read my last post you see that i have a problem for install game and launch.
-second, i see that i can only launch glidos and original tomb raider 1 if i choise windowed mode for glicos msdos shortcut in glicos directory.
If i choise full screen the program launch vdmsound and after i see two line with dos/4WG and it's blocked, game don't launch.
For tombub.exe it's different to tomb.exe because glicos change the glicos.bat in c:\tombraid and don't put the gdlvesa instruction:
if i launch tomb.exe with glicos, glicos.bat contain:
DOSDRV
gdlvesa tomb.exe
but if i launch tombub the glidos.bat is:
DOSDRV
Tombub.exe
i'm sure it's work if it's
DOSDRV
gldvesa Tombub.exe
but if i change the .bat line and relaunch glidos, glidos always change the .bat to
DOSDRV
Tombub.exe
I try to launch a dos windows and do manually but i have message error servor, the program launch and work but i can't see it at screen! (i hear the music and i know it's work).
I test with the original tomb.exe and same prob.
To work i need to launch Glidos because manual command don't work (i don't see the game at screen but he work!).
What can i do for this prob ?
