First post, by jeffareid
When I run Glidos (1.42) in windowed mode with TombRaider, the window is offset down and to the right. I have to manually recenter the window on every load or level change. Is there a parameter I can adjust to fix this?
Reply 1 of 1, by Glidos
Yeah, that's an annoying consequence of using the Direct3D branch. Two possible solutions.
1) I think the window position is relative to the Glidos dialog, so if you move that dialog up and to the left before starting the game then you can get the game window exactly where you want it.
2) Select OpenGL in the config.
