First post, by Skullcrusher
First I tried to play the game without Glidos. It says Unable to setup DirectDraw - please check that DirectX is installed. Then I tried Glidos. Got the same error.
Then I downloaded carmav.exe. Now if I start the Carmageddon through Glidos using either carmav.exe or 3dfx.exe I get NTVDM.EXE has stopped working.
After that I downloaded DosBox version from Glidos site. When I run it through Glidos + DosBox it works. It works, but without sound and it asks for a CD if I try to start a new game.
I need some help here, because I won't get it working on my own.
