First post, by AustinRover
I have just bought Glidos and have TR1 working nicely on Win7 64-bit with DOSBox.
I was wondering, though, is it possible to reconfigure DOSBox so that rather than mounting the actual CD drive it mounts a CD image instead? I know this is possible with DOSBox, but I can't see where the Glidos DOSBox is getting its startup/autoexec config from.
I would like to play the game without having the physical CD in the drive of my laptop all the time.
Thanks,
AR
Reply 1 of 12, by AustinRover
It's OK, I figured out how to do it. After a bit of delving I found that the startup commands are hard-coded in glidos.exe.
In c:\program files (x86)\glidos\ there's a minimal dosbox.conf. I added the following to it:
[autoexec]
imgmount e c:\path\to\cdimage.cue -t iso
Luckily this runs before the hard-coded startup parameters so that when Glidos issues "mount e f:\ -t cdrom" it just fails with an error message about drive letters.
Reply 3 of 12, by ShinobiNinja
I know this thread is very old but I can't get AustinRover's method to work.
I use Glidos 1.50 and attaching the command to the dosbox configuration file seems to have no effect as the CD is still required and the commands in the dosbox windows are still the same as always.
Reply 5 of 12, by ShinobiNinja
Thanks for the answer but I still can't get this to work.
Could you please help me?
How would the .bat file or the dosbox.conf have to look If I had my image C:\TOMBENG.iso?
Help would be very appreciated, as I'm not that skilled with those things.
Reply 6 of 12, by Glidos
Ah, I replied without looking through the previous posts and my advice was based on another way around the problem. Have a look at the Glidos facebook group where the other method is mentioned.
Reply 8 of 12, by gidierre
use cue/bin format
an iso won't do (unless you don't mind missing cdaudio tracks rendering)
We often forgive those who bore us, but we cannot forgive those whom we bore. (La Rochefoucauld)
Reply 9 of 12, by Glidos
Here's a guess at the bat file you need. You need Glidos running, but don't use Glidos's "Start Game" button.
    StartTR.zip
    258 Bytes
    493 downloads
    BAT file that might with luck start TR from an iso and run it through Glidos
Reply 12 of 12, by Glidos
ShinobiNinja wrote:
There's an error message saying "Illegal command: D:\Program." when I use the .bat file.
Ok right. Try the new one attached below. It also has some changes because you are using 64bit Windows. It may still not work, but maybe we will get there eventually.
Can't you somehow implement a cd image function into Glidos?
Yes, hopefully when I can find some spare time. Indeed, these tests may help towards that eventual goal.
    StartTR.zip
    267 Bytes
    479 downloads
    Another attempt at a .bat file for using Glidos with a CD image
