First post, by karaknic
Hi all,
I've been banging my head over this for a while now and can't seem to find a solution.
The problem is after I've installed the pre-made GliDOS files for TR1 and install + activate VDOS32 I then go on to start the game from GliDOS and it comes up with an error window for VDOS32 saying
"Failed to open file (Path to Tomb.exe) -- set "PATH=(path to GLiDOS
I thought it might be windows stopping the access of stuff on the C: drive, so I moved all program files (for GliDOS and VDOS32) and TR1 files on another drive, but same problem persists.
Running the game straight with VDOS32 using the different TR1 pack works fine, but obviously it's windowed and graphics are blocky.
Thanks
